May 15, 2024, 05:58:48 AM
722 Guests, 0 Users
  • Online today: 747
Guests: 722
Total: 722
DIY Push-Pull TPM Controls Help
Started by obsoletepower, February 27, 2018, 09:08:19 AM
obsoletepower
Hi everybody! I have been contemplating for some time now whether to incorporate real push-pull controls into my sim cockpit and although it would be easiest, it would not be as much fun, educational and challenging as building them from scratch. Not to mention I would have $300+ in my pocket to spend on something else. I was thinking of 3D printing the three knobs, using some stainless steel push rods and building a slide potentiometer board. I don't need friction/push-button locks and can do without vernier controls; just simple push-pull.
I am trying to source the panel mount conduit + nut (pictured below and highlighted with red square) but I cannot seem to find anybody that sells just that component. Would anybody have a suggestion as to a generic replacement / oem source for it? I would be greatly appreciative of any help.
obsoletepower
Thank you so much for the suggestion. I did check AircraftSpruce before but they did not have replacement parts for TPM controls apart from spare control cables. I think maybe 3D printing is a good alternative as having those components machined will probably be more expensive than just buying the controls.
_alioth_
I made something similar to make my push-pull vent levers.
Start with 3d design..
3d print, and shopping... with a total amount of... 15$
knobs are 1€ each :)  http://www.leroymerlin.es/fp/16310350/pomo-abs-jade-negro-mate-serie-infantil
Start to join everything..
Looking good..
Pots.. wires..
A cover.. so it won't be any problem with dust in future.
I have only three knobs. Left one control Vent. This one open/close every vent knob (4 of them) in the simulator.
Testing..
http://www.youtube.com/watch?v=ZGRqDr4qAYk
Works perfect!
Now, Im using them as a TPM throttle quadrant, until I finish the real throttle quadrant I will use :)
Arturo.
mikeybear
Thank you Arturo, that is a brilliant idea.
May I ask what are, and where did you get the bushes from ?
Dave
obsoletepower
Quote from: _alioth_ on March 01, 2018, 06:38:40 AM
Looking good..
Pots.. wires..
Testing..
Works perfect!
Arturo.
Thank you so much for this suggestion! Looks amazing!!
_alioth_
Quote from: mikeybear on March 01, 2018, 01:44:11 PM
Dave
They are 8mm "portaled". I dont know how is said in english.... led supports..
Very easy to find in any electronics shop.
mikeybear
mikeybear
Hi, Here's my version , its a single slide pot, for the Inertial Separator , I've used telescoping brass and aluminium tubes and CNC machined PVC sheet ( 12mm , 4mm qnd 2mm)
Dave
