May 15, 2024, 09:26:30 AM
740 Guests, 0 Users
Guests: 740
Total: 740
737 Circuit Breaker panel lights
Started by Winstonc, June 14, 2018, 10:04:53 AM
Winstonc
I will be adding CB panel lights to my cockpit and I am looking for close up pictures of the 4 lights (1 FO side in the roof panel, 1 on each side in the side panel recess and one on the Captain side on the diagonal window rail).
I need detail pictures as I intend to draw them up in CAD and 3D Print / laser cut as appropriate.
If anyone can help, I would be most grateful.
I believe the two side panel lights are standard Grimes model MS25027-1 lights. This is in the classic, not sure if they changed that for the NG.
Winstonc
Yep, those look right.  Thank you.  2 down two to go.
Gallie
You forgot one. There are 5 CB panel lights.
- FO ceiling panel
- FO side panel/below window - grimes p/n 15-0121-2
- FO on floor behind the pilot seat.
- CPT on sliding (DV) window rail
- CPT side panel/below window - grimes p/n 16-0255-1
p/n are from my classic parts, they are also different revision lights, but i dont see a difference.
will try to post some pictures tomorrow.
Michael
Winstonc
Slightly off topic - the Sismo overhead circuit breaker panel rheostat actually turns on or off (with brightness) the light which is located right above the knob. I know that is not a circuit breaker light. So what actual knob in the aircraft controls that light?
Gallie
The light in the FWD overhead frame is the pedestal flood light
Hi David
Just FYI I did not try to emulate the real lighting, instead I used 2 Wemacs
High load 24v  bulbs were replaced by 12v led equivalents which emit no heat
B737NG
Steve Wekarchuk
'B737NG'
Gallie
Here are some pics of the FO floor breaker light
Dimensions are in CM
cheers,
Michael
Winstonc
Thanks guys for all the info.
This is the link to my latest video on the cb's
https://youtu.be/6_GRCG5CPxE
B737NG
Looking awesome David. Good thing I'm not a hand model, or I'd have to charge you!  ;D
Steve Wekarchuk
'B737NG'
