May 03, 2024, 04:38:23 PM
546 Guests, 0 Users
  • Online today: 831
  • (Today at 12:39:25 PM)
Guests: 546
Total: 546
Great Arduino video
Started by FSAddon_boss, October 06, 2021, 01:03:38 AM
FSAddon_boss
Great to me, that is, as a total novice on all of this stuff.
It appears that I have the WRONG Arduino board though, as it is not one that can relay keyboard commands ???
The man who made the video is many steps ahead of me, and has a 15 year reserve ga pin age, but things like these are helping me a lot!
I now plan to dismantle my Flightlink switches and use them to connect to an Arduino (bread)board to toggle the switches in X-Plane. The EPIC board is just too old and too much of a black-box.
https://youtu.be/A5s_9UNFDck
Francois
Francois A. 'Navman' Dumas
retired
Francois,
Before you get too involved with the arduino coding, have a look at Mobiflight.
There are lots of tutorials and it does work with X-Plane by using a plugin that works like FSUIPC.
Worth a look
https://www.mobiflight.com
Jason L
A big second behind mobiflight.  Very easy to use and continuously updated.  Supports 3 different arduino boards if I remember correctly.
_alioth_
Although mobiflight is quite good I have to say you should try with arduino code. Mobiflight has its limits.
If xplane, then teensy board with Teensyduino plugin.  https://www.pjrc.com/teensy/td_flightsim.html
If p3d, arduino + fsuipc LUA script.
If you can learn it, the only limit will be your imagination.
If you think the learn curve is too much, then mobiflight can do the job.
Another vote for Arduino/Teensy.
Mobiflight is good, but there are several limitations still, especially when using Stepper motors..
I prefer using Teensy 3.2 devices connected directly to X-Plane. No middleware involved.
The only drawback to using the PJRC Teensy 3.2 plugin is it only works with the Teensy 3.2 devices.
With that said, my sim has about 15 of them installed without issue.
_alioth_
Quote from: RayS on October 06, 2021, 10:04:11 AMThe only drawback to using the PJRC Teensy 3.2 plugin is it only works with the Teensy 3.2 devices.
I only use p3d. But some time ago I tested teensy 3.5 with xplane and worked great. Is there any problem with 3.5?
https://www.youtube.com/watch?v=1TnGI2Vj_S4
In p3d, with a lua script in fsuipc for serial data transfer, you can use whatever you want.
I use arduino mega, arduino due, arduino micro, and teensy 3.5 in my cockpit...
FSAddon_boss
Thanks for all the comments. I looked at SimVim and MobiFlight too....... they both are interesting in terms of ' ease of use'..... but being an ancient programmer AND hoping to use my simpit for more than one sim, I am still leaning towards Arduino and doing it myself..... My main hurdle is electronics, of which I know next to nothing.... not programming.  :D
Francois
retired
Quote from: _alioth_ on October 06, 2021, 11:50:15 PMI only use p3d. But some time ago I tested teensy 3.5 with xplane and worked great. Is there any problem with 3.5?
It depends on how it's implemented. If you are using the 3.5 in conjunction with LUA scripts then it should be fine.
In my case I'm using the TeensyDuino plugin which only works with Teensy 3.2. https://www.pjrc.com/teensy/td_flightsim.html
However, you could use a Teensy 3.2 as the master device and it could be set up to drive other controllers via the serial interface.
_alioth_
Quote from: RayS on October 07, 2021, 02:52:33 PM
I asked beacause I tested teensy 3.5 with teensyDuino and x-plane plugin and worked great.
I have read there was a problem with tensy 3.5 and float variables in the xplane plugin. But It was fixed and now you can use teensy 3.5 fine.
Quote from: _alioth_ on October 08, 2021, 01:18:05 AMI have read there was a problem with tensy 3.5 and float variables in the xplane plugin. But It was fixed and now you can use teensy 3.5 fine.
I'll have to give it a shot this weekend. I've a few spares collecting dust. Thanks for the Info!
