Main => Help and Support => Topic started by: kozak737 on September 03, 2010, 11:24:04 AM
I try to put the rotary switches with long shaft and i don't understand how it is possible to put on the top the knobs, since it is too long. Should I cut the shaft?
Constantinos
That's what I did...
Install the rotary tight and then spend a little time measuring carefully because if shaft is cut too short you loose the rotary!! Allow 3 to 4 mm between the panel surface and the bottom of the knob.
