May 21, 2024, 12:02:08 PM
729 Guests, 0 Users
  • Online today: 748
Guests: 729
Total: 729
CP MIP 737 card and switches wiring
Started by kozak737, July 23, 2010, 10:34:13 PM
kozak737
I build up a 737 simulator and I am using the cp737 card. I wired all the switches but i am not sure if the commands are correct. Has anybody the commands list of the switches, I contancted the CP flight but they are on holidays
Thank you
Constantinos
Which switches? MIP, Overhead' pedestal
Here is an overhead interactive
http://artietheairplane.com/737_panels/737_main.htm
click on anything you want to know about ..ie: type and function of a switch
also
http://www.b737.org.uk/
There used to be more of that type...Guys???
hello constantinos...........
sorry, but i'm not 100% sure what you mean.
all the connections for in and out are contained in the MIP737 manual. you can find it here
http://www.cpflight.com/sito/downloads/mip737mi105.pdf
this may help you out.   or if you get real stuck, come back and ask, but be more specific please
and that may help me to understand your problem better.
enjoy tomorrow captain.....
regards from wales...  ian
kozak737
I refer to the switches and rotaries of the MIP, when I turn the rotaries, they show one command, that command cannot specify if it is correct or not. I have sent to the CP flight but they are on holidays so they could not help at the moment. The rotaries are working, just i do not have their confirmation if  they are connected correctly and if their function work properly.
Thank you Captains
Constantinols
Still unclear.
I checked the Pdf mentionned by Ian and it is all there..
Do you use Project Magenta ?
JP
kozak737
Hi captain Jack,
I am using flight deck software. It is not unclear.  There is one sheet where all commands is there.  I suspect that some they are not working properly. The flightdeck software doesn't support 100% the MIP 737 so the wires are loose.
With regards
Constantinos
dnoize
flightdecksoftware supports most (if not all) of the inputs of the mip737 board.
If you wired them correctly they should work ?
What rotaries do not work ?
Do you see them work in the cpflight testprogram ?
what rotaries do not work ? I will ask Bart to check. I have a direct communication line with him.
Stef
kozak737
Hi Stef,
I use the cp test program. They are working using the cp program test, but most of them repeat the same input number.  I don't have a list of input to confirm them. I ask from the flightdeck to send me the rotaries that they are working but until now I don't have it.
Constantinos
dnoize
each input should give an individual number in the testprogram. If you get the same number for several inputs its means you have mixed up the grounds on the mipboard sight or have soldered the wires wrongly on the switches.
I would suggest to disconnect everything and wire just a few simple switches to test (some pushbuttons or toggles) within one group. When these work, progress slowly wiring group by group and test after each group if you get individual numbers in the test program.
If you get all the same numbers in the testprogram it will not work in Flightdecksoftware ofcourse as it does not get the correct information.
The DU rotary switches, afds, landing gear, etc should all work correctly in flightdecksoftware !
Stef
kozak737
