May 09, 2024, 01:02:35 PM
573 Guests, 0 Users
  • Online today: 588
Guests: 573
Total: 573
Trees on taxiways P3D 4
Started by jackpilot, February 28, 2022, 05:32:18 AM
Found some trees on taxiways in Orlando (only)
Just default scenery
(Only ORBX Global and Vector installed)
Am I alone with that ?
Quote from: jackpilot on February 28, 2022, 05:32:18 AMFound some trees on taxiways in Orlando (only)
You aren't alone, but If I remember right there is a fix for it in the orbx forums.  I experienced that a long time ago.
chillywillies
Hi Jack!
You can diagnose the issue in most cases by using the ScruffyDuck Airport Scanner. It checks the scenery index file for duplicate BGLs in the index that can cause that. If I remember correctly, I had this issue specifically with Vector and MCO in v4, but if you want you can try running the scanner first and post the results. Basically, you want to use this tool to locate the file path(s) of the duplicate and least accurate/default BGL files.
https://www.fsdeveloper.com/forum/threads/simple-airport-scanner-1-70-beta.440300/
Hope this helps! :)
Streamer fascinated by simulator cockpits, knowledge in simulator software/config primarily
Build:
i9-10900KF, 64GB 2933MHz RAM, ASUS Maximus XII Hero, 2TB Samsung 970 NVMe, EVGA 2080Ti
