May 16, 2024, 04:59:06 AM
742 Guests, 0 Users
Guests: 742
Total: 742
Autopilot Disconnect Offset
Started by Trevor Hale, February 27, 2015, 03:26:29 AM
Hi Guys. I have Tried for 2 days to make this work, and I am having Issues.  I am wondering if any of you can Help.
0X04F0
MCP/FCU Lights (Read Only) Boeing-Type MCPBit Light 0 A/P Master L (1)
1 A/P Master C (2)
2 VS
3 ALT HLD
4 APP
5 LOC
6 LNAV
7 HDG
8 FLCH
9 SPD
10 THR
11 A/T
12 F/D
13 A/P Master R
14 VNAV
15 Mach
In GF Display I can get the autopilot Engaged light on with the following
L1.0=C0 X4F0 U16 M1000
No Problem.
Where the Problem Resides is trying to get the Inverse for Autopilot Disconnect.
- I Have Tried by adding the Mask of M0000
- I have Tried by adding the U16 <= 16001  Which kina worked through FSinterrogate But the light would go on and off depending on what functions were enabled on the Autopilot.
- I have even Tried Switching to offset L1.0=C0 X50A U16 M2 which should be Bit 1 Mask.
In Any Case, I can't seem to get anywhere with 050A.
I am Also Trying to use oX04FE for Altitude Warning Annunciator and can't seem to get the Mask for Bit 10
L2.0=C0 X04FE U16 M400 (Bit 10)
That Also doesn't work.  Has anyone had success with these offsets before?
I am at a loss.
Hi Trev,
Are you using FSUIPC or simconnect for data from fs?
Hey Kyle. I think he is using FSUIPC.....
I see those offsets are blocked off for Project Magenta. I assume your using that.
Don't know, but would the fs autopilot work for the indicator display? Offset 07BC for the master switch.
Quote from: KyleH on February 27, 2015, 04:30:24 AM
I thought of checking that, but I don't think the PM Autopilot uses the same FS Autopilot.
http://www.projectmagenta.com/pmoffsets/
I will check oX0504 with FSinterrogate tonight, maybe that is where I need to look.  Seems to be very picky.  I just noticed oX050A is for Physically writing or Disconnecting the autopilot.
