May 16, 2024, 04:46:54 AM
740 Guests, 0 Users
Guests: 740
Total: 740
PM 738FSX PLANE
Started by tugo31, May 25, 2015, 01:22:04 PM
I understand better.
Ok for reflections and added realism.
I dont care either for exterior views with my setting obviously.
My prob now is that what I have for taxi/landing is far too bright and whitens everything in front including center line and runway lights.
Now, Is it compatible with Opensky models and FS9 ?
tugo31
Quote from: blueskydriver on June 09, 2015, 06:09:23 AM
Okay, to clarify, you are talking about how the taxi light illuminates the ground in front of you right? If that is the case, can you check the "advance animations" in the FSX settings and see if that changes the brightness. I want you to check and see if something else got changed somehow...
Hi John, the FSX advance animations have been always checked.
This was the last web forum i asked for help, i been dealing with this a long time ago without finding a working solution and im giving up, i would like to thank all for your time on this.
I will have to fly in daytime  :(
Juan
Andrew 737
In the avsim library there is a default 738 taxi light fixer, use it!
Then you will have to try and swap the model from the fixed 738 to the pm 738 - I believe it's th same unfixed model!
I did it before I used ProSim and it worked!
Back Up 'EVERYTHING' first
Regards and Thanks
Andrew
