May 21, 2024, 08:31:37 AM
722 Guests, 0 Users
  • Online today: 748
Guests: 722
Total: 722
B737: measures from sidewall
Started by MjTom, January 04, 2016, 03:49:57 AM
MjTom
Hallo
First, I wish you all a Happy New Year !
The last few weeks I have been very diligent.
But now, I need some Measures to finish the sidewalls.
I would be glad if you had some information.
1. the cutout for the lighting from the circuit breaker:
2. the center of axis from tiller to make the drilling:
Thank you, Thomas
Buster99
Hello Thomas,
I have the dimension for the total tiller height (I do not have distance A in your picture).
The center of the tiller axle is 57.5 cm from the bare cockpit floor.
This was measured from an actual stripped 737-600NG flight deck (see attached picture which is CPT side)
I hope this helps,
Best Regards,
Marc
MjTom
Hallo Marc, thank you for answer!
57,5cm viewed from insinde looks perhaps a little bit too deep.
Is it possible, to get the measures from inside (the yellow arrows)?
My dimensions from sidewall are approximately +/-1% by the originals.
Thus, I expect a good result from measures from inside.
I envy you for your real cockpits ^^.
only chance for me to get: go to EDFH and dismantle a parket B738 from Rynair....Tony Ryan has enough of them.
"sorry"  for the inconvenience, I´ll try as real as possible.
so long, Thomas
MjTom
Hallo
I want to show you one of my modes of operating if I have no or no real measures.
I only need a good photo with ruler...that's all the help I need, nothing spectacular.
one photo from my HC and one from original
moved and adjusted
one above the other
In this way I am 100% on original.
so, a small photo spared massive work.
thanks to all, who make it possible.
so long, Thomas
quid246
If you can wait until next week, I'll take measurements from a real NG.
Buster99
Hello Thomas,
57,5cm is the correct measurement from the bare floor to the center of the tiller axle.
Measured from real 737-600NG, alas, not mine!
I do not know how this translates to your setup, that is something you will have to compare and adjust as necessary.
HTH, Marc
MjTom
~57cm is definitly the correct measure.
I now have all what I need to finish the sidewalls.
thanks a lot to all !
the next phase of construction: fill in.
I will keep you up to date.
so long, Thomas
