May 20, 2024, 03:29:47 PM
735 Guests, 0 Users
  • Online today: 743
Guests: 735
Total: 735
XPUIPC
Started by Bob Reed, April 13, 2016, 05:08:52 PM
Does anyone now how to program a switch in XPUIPC to an offset?
Unfortunately, that can't be done. While XPUIPC is great at porting over nearly every offset in FSUIPC, that's pretty much where the good stuff ends.
However all is not lost. The Teensy X-Plane Library can address X-Plane Datarefs directly, which is pretty much the same thing.
Ridgenj
Bob, you have a Teensy so it will be a piece of cake
Bob,
Teensy only works with x-plane datarefs, commands, and Strings.
Quote from: 727737Nut on April 14, 2016, 06:36:20 AM
Bob,
You can also access a library that will access offsets directly so I am told. If that is true I will have to change the interfaces on my yoke and throttle.
Spyy
If you mean a joystick switch you can do it in the xpuipc menu under xpuipc+
Torsten
Quote from: Spyy on May 18, 2016, 11:40:05 AM
Torsten
What pulldown menu? I have not seen one....
Spyy
Hi Bob,
Under plugins->xpuipc->xpuipc+->...
I think its in since approx V 2.0.3.0 or so....
Torsten
MjTom
Hello,
I find another version XPUIPC.
I'm still filling in and painting .... no end in sight
so, I don`t know and can test, what the modifikation will bring about.
The page have a bad server....have to try it more often until the connection works:
http://german-xflight.de/resources/xpuipc.6/update?update=21
XPUIPC 2.0.4.8
Small adjustments
x737 Support
TCAS function added
...so long
Quote from: Spyy on May 19, 2016, 11:08:55 AM
Hi Bob,
Torsten
Where do you get that version? I am using version 2.0 I see no other version.
MjTom
...another link:
XPUIPC Version 2.0.4.7 (Released 24th April 2016)
This version was released to fix some issues with the IXEG 737 autopilot.
Download: http://ticket-system.org/efasswiki/images/6/68/XPUIPC_2.0.4.7.zip
Installation
Go to <X-Plane>\Ressources\plugins and delete your old XPUIPC folder. Thereafter copy the folder from the ZIP-File to that directory. Restart X-Plane.
Ok... How did I not know about this version of XPUIPC before? Do all X-Plane users know about this? Ver 2.0.4.7 is what I am using now. There is a drop down menu for joystick buttons that you can assign offsets for! Yes Offsets!! My PM AT disconnect, AP disconnect and TOGA buttons now all work. This is OUTSTANDING!!!!!  :idiot: :idiot:
MjTom
I try to learn something about simulator software.....but so far no plan.
Therefore I read everything I can find.
I think I have finally a beautiful HC, but that, unfortunately, can not fly. The XPUIPC: I found by chance.
It makes me happy that I could help you this time.   ;D
so long, Thomas
