April 24, 2024, 10:44:29 PM
350 Guests, 0 Users
  • Online today: 393
Guests: 350
Total: 350
Speaker distortion
Started by Mach7, November 04, 2019, 06:36:29 AM
Hello,
I have the Buttkicker gamer installed in my flight simulator setup, using PM sounds.
The kicker works fine, however I am finding a lot of distortion through the right speaker when PM sounds enhances wind noise, gear lowering, autopilot disconnect tone, or any other callout, verbal or otherwise.
I have not changed the setup since installation and was wondering if there is a quick fix for this. I have not ruled out a speaker issue, however with the right speaker input disconnected, the sounds are no longer distorted.
Thank you
If it were me, I would hook up a cheap PC to the Butt Kicker, then using PMSounds only on this PC, I'd turn off all the sound files that wouldn't sound right going through it.
The disconnect tone or wind sounds are high frequency and not something you'd feel in the cockpit. Whereas the nose gear coming up into the nose wheel well you would; thus, you only checkmark the sounds you'd ordinarily feel in the PMSounds program.
That could be the reason you're hearing or feeling the distortions, but for one side to sound bad and not the other is weird. What happens when you totally remove the butt kicker, does the right side still sound bad through the regular speakers?
That's an option for sure John. And yes...the distortion goes away once the feed is disconnected from the kicker.
