May 16, 2024, 05:29:47 PM
712 Guests, 0 Users
Guests: 712
Total: 712
Can you run out of USB ports?
Started by navymustang, April 15, 2022, 12:20:55 PM
My sim is at a point I can't add any additional USB devices. I have two 6-port hubs and one 10-port hub, all powered and the voltages are good. The 10-port is USB 3 and plugged into a USB 3 port on the PC (with a USB 3 cable), the others are USB 2.
No matter where I plug in (back of PC, a hub or front of PC, same error:
"Insufficient resources exist to complete the API"
It also does not matter what kind of device, mouse, Arduino, Leo Bodner, etc.
I upgraded to the latest BIOS (Z87 CPU) and have the latest patches installed for Windows 10.
HELP !!!
I ran into that at one point. Make sure your hubs are of the "Multi Transaction-Totalizer" per port, not per hub.
Typically these are referred to as "Multi TT" hubs. Otherwise, Windows will try to manage a tsunami of data packets using only 1 traffic cop.
Difference between Single and Multiple TT USB Hubs
Also, make sure you aren't daisy-chaining your hubs together. And those cheap knockoffs don't work very well. (Just saying that as a matter of record)
Looked a bit closer on your images.  You might be out of COM ports as well.
You may have to go with a master/slave architecture for your arduinos.
This is exactly what Bob Reed and I were working on before he passed. We wanted 1 device as a the master with up to several as slaves.
OK, using substitute hardware I was able to confirm that it is not a USB hardware issue. That is, my hubs are fully functional.
And just for the heck of it I did a safe boot with the USB still operational. And OMG - all the USB ports started working as they should. So now I have to figure out a debug method to determine what is being loaded into memory that is limiting the USB ports. It is not any of the startup programs, I ran that test already. So there is something that Windows is loading (drivers, etc.) that is creating the issue. I thought at one time you could tell Windows to do a safe boot then step wise load all the additional stuff. I don;t see that option anymore. More reading ahead to figure this one out.
Hi Jim,
You might consider going back to a Restore point in your Windows computer to a time where you did not have this issue "pop up".  Although...   When Windows does an Update, it typically deletes previous Restore points.  That said, it is worth checking...
If you make "Image Disks" of your computer Op System and Data, you might try going back to an earlier Backup of your system.
-- Check your PM
I wish I could do that, but as you said, the latest Windows update killed my previous restore points.
Hey Jim,
Read this:
https://helpdeskgeek.com/help-desk/how-to-fix-not-enough-usb-controller-resources-on-windows-10/amp/
Why this doesn't happen in safe mode is because you're not using all the USB endpoint resources yet. Outta safe mode, your PC is using more of these endpoints that take away from your USB devices....
John  :D
paulnd
Quote from: RayS on April 15, 2022, 02:49:06 PMYou may have to go with a master/slave architecture for your arduinos.
Hello, I'm interested in what you were planning, I'm thinking of something similar and weighing up a few options.
Paul
My Arduino suite are all running under AirManager. So the Master/Slave concept is not necessary.
Well, the endpoint issue might still be part of the problem, but I resolved it (for now) by just reducing the number of hubs I had. Turns out each time I plugged in a 10 port hub, it generated 5 additional hubs (shown in device manager). What the hell?
Another idea is too make sure all hubs are the same speed, be it 3.0 or 2.0 and plugged into the same port type on the PC. Also, you probably don't do this, but avoid hub to hub...too many transfer points.
This problem really should be solved with Ethernet. IMNSHO.
paulnd
Quote from: ame on April 22, 2022, 09:25:40 PMThis problem really should be solved with Ethernet. IMNSHO.
I agree completely and one of the options which I'm considering. When I started investigating arduino/ethernet a few years ago, the shields and libraries which I tried weren't that reliable - does anyone have any recommendations?
Quote from: paulnd on April 23, 2022, 04:52:19 AM
Well I started my experiments with an enc28j60 on an Arduino Nano. I could not do the UDP multicast stuff to get the X-Plane beacon packets, but that's ok because I could just set the server's IP address as a parameter in the Arduino.
I was able to issue requests for compass heading and instrument brightness (I was building an illuminated compass), and I saw the request in X-Plane's log, but I didn't seem to be able to get data from X-Plane. I suspect that X-Plane was correctly sending it to the originating IP address (the Arduino) but that the Arduino was not receiving it.
At that point some other stuff was happening, so I gave up.
I really ought to try again. I also have a Wiznet module which I could try.
Sticking an Arduino on the network would be a great solution to the problem of limited USB cable length and which Arduino am I talking to? That Arduino can do a lot of immediate work with switches, LEDs, and other peripherals, but it can act as a hub for other i2c modules (for example) or other Arduinii.
As pat of my debug strategy I ordered a new 20 port USB powered hub.
In the instructions were the following lines:
To give access to all 20 ports you may have to open the BIOS and shut down XCHL mode and USB3.0 ports.
I have an ASUS board and found the settings, and sure enough all my USB devices are now online. OK, not at USB 3 speed, but none of the devices are data storage related, just drivers for low speed button and analog acquisition stuff.
I couldn't be happier. Now I can continue working.
Quote from: navymustang on May 01, 2022, 10:57:34 AMAs pat of my debug strategy I ordered a new 20 port USB powered hub.
Interesting...
What is XCHL mode?
What powered hub?
xCHL mode is in the BIOS and it is a software module that allows USB 3.0 ports on your computer to communicate at all speeds (USB 3, USB 2 and USB 1). Otherwise, the port only recognizes USB 3 devices.
The issue is that USB 3 eats up TREMENDOUS amounts of resources and if you follow this message post trail, you will see I ran out of available services with all the USB devices I have.
The only down side of disabling USB 3 is that all the blue USB ports on the back of your PC get shut down. However, the upside is that you can run a hell of a lot more USB 1 and USB 2 (black or white ports) devices.
The powered hub was an industrial strength unit I bought on Amazon for around $200.
