May 05, 2024, 12:34:13 PM
529 Guests, 0 Users
  • Online today: 567
Guests: 529
Total: 529
Airbus Trim Wheel
Started by brianwilliamson, January 22, 2021, 04:08:25 PM
brianwilliamson
Gentlemen I need some help with a trim wheel for the Airbus. Ok I know most here are Boeing, but the principal is the same.
I have had it working for some years without a problem until the IOCard DC motor decided to do a runaway and tear the stops out, so I rebuilt everything including a new DC Motor Plus from O.C.
I also installed a 10 turn pot. which I suspect is giving me problems.
Having said that as the bare outline of my problems, apart from not being able to get the Plus card working, the 10 turn pot. has now given false readings.
So what do you fellows use for the pot. and are you using the Opencockpits USB motor or the Plus ?
Any help would be appreciated, before I go to the bottle shop for supplies. The frustration using some of the Opencockpit stuff really tries the patience out !!
The 12 v. motor is geared very low and I had it working in the software to slow down before it reaches the stop position and the rpm is much lower than the 737.
You cannot view this attachment. So basically it runs the trim wheel directly off the motor which has the 10 turn pot. connected directly to the end shaft of the motor, which only needs 6 turns approx.
regards............Brian W
plus 3 control computers.
