May 16, 2024, 02:17:46 PM
729 Guests, 1 User
Guests: 729
Total: 730
archen Multisim project
Started by archen, April 05, 2020, 12:15:27 AM
This is some beautiful Stuff...  Thanks for sharing this with us.
archen
Hello Trevor,
Thanks for the kind words [emoji4]
If anyone would be interested I'll make the plans available for anyone that wants to build it. Problem is they are not DIY friendly and you kind of have to have a cnc.
Anders
Skickat från min SM-N986B via Tapatalk
Anders Simparts
http://www.anderssimparts.com
archen
CAM done in F360. It took quite some time before I could figure out how to setup the part in a 7.5 degree angle.
I'll have to mill two fixtures to hold the piece. I'm at the moment out of aluminium so no machining until next week.
Gonna be interesting to see if this works. If anyone has experience of this, please shout out [emoji16]
Anders Simparts
archen
Small steps forward.
Today I machined the part that attaches to the yoke. It has a 7.5 degree slope, the other part that attaches to the shaft also has 7.5 degrees slope so the yoke will lean 15 degrees in relation to the shaft.
Quite happy with the result. Some improvements if I where to redo the part but in the end it doesn't matter. Would just help out to make it easier to mount.
Anders Simparts
archen
Part2 finished.
Anders Simparts
Beautiful work on these parts Anders!
CAD/CAM in Fusion 360 is very convenient, although it is not intuitive -- especially when it comes to creating geometry using multiple planes.
By the way...   Your Start Switches are still working fine in my 737 Sim.   "They take a lick'n, and keep on tick'n"   :)
archen
Quote from: sagrada737 on November 02, 2020, 06:02:48 AMBeautiful work on these parts Anders!
Awesome to hear, love hearing they still work after years of usage [emoji7]
F360 takes quite some time to figure out all tricks. I follow some quite nice tutorials on YouTube. Still learning everyday.
Anders Simparts
archen
Quote from: jskibo on November 02, 2020, 08:04:23 AMAnders is a master craftsman!
Thank you so much!
Anders Simparts
archen
Some more work. Now they are being painted before assembly.
Anders Simparts
Hello Archen,
Regarding AutoCAD's Fusion 360...   Here is a very good set of tutorials for using Fusion 360 in CNC applications.   I purchased the Fusion 360 for CNC Lathe work.  It is very comprehensive as to each step needed to setup and use the CAD/CAM operation in Fusion 360.   I think it could be of great help to you.  Here is the link:
https://course.gcodetutor.com/p/fusion-360-tutorial-for-cnc
Go to his home page for all his tutorials...
archen
Awesome. Thanks for sharing!
Anders Simparts
archen
Painted, now time to cut the shaft to the correct lenght.
Anders Simparts
archen
Had to make a new shaft, I made a mistake in my design so it was to short.
Now it will leave around 15cm space behind the panel and also 15cm between the yoke and the front panel when it's mounted in the Sim.
Lots of work as the bearing was heated to make them fit it was very hard to get them apart. I'm not taking it apart again, that's for sure [emoji16]
Anders Simparts
archen
Designed a bushing to support the shaft in the front. It will be manufactured in Acetal (delrin).
Anders Simparts
Would a flange bearing be a better option there Anders? Assuming you get get one the right Size for the shaft... Just a thought!
It's looking magnificent none the less.  :D
Joe
archen
Hello Joe,
I think a hardened shaft is a must if I should use bearings. The shaft is not hardened unfortunately.
Anders
Anders Simparts
archen
Machined the part today. Now it's going into the lathe to trim the outside diameter and also make the inner hole the right size. I think I'll do h8 tolerances, seems like most bushings are h8.
Anders
Anders Simparts
archen
Completed. Ready for mounting.
Anders Simparts
archen
Two new pics showing the casing.
Ideas how to make the 7.5mm radius bend?
Anders Simparts
Quote from: archen on November 17, 2020, 02:24:41 AMTwo new pics showing the casing.
You could use a brake press, like the one in this video:
https://www.youtube.com/watch?v=nF0GCCKRcvA
I made one using birch plywood for bending aluminium. to form a radius you simply machine the inner radius on the part you're bending it around.
I hope that makes sense??
archen
Many thanks Joe! [emoji16] Great idea
Anders Simparts
archen
Front finished. Now some adjustments to make it smooth..
Anders Simparts
