April 28, 2024, 10:18:31 PM
486 Guests, 0 Users
  • Online today: 498
Guests: 486
Total: 486
Change bulb AFDS
Started by kurt-olsson, February 27, 2021, 11:48:46 AM
Unfortunatly one bulb is broken on my AFDS and needs to be replaced.
Any instructions on how to open the pushbuttons?
I really dont want to brake anything so help on "how to" would be appreciated.
There are small recesses on the side of the button head, grip these with your fingernails and the head of the button should pop out about 3/4" and is retained by small metal bails.
The head of the button can then rotate 90 degrees and the bulbs can be replaced from the back.
They use #387 28v bulbs.
I can take photos if needed
Thanks Mick ill give it a try!
Also, my AFDS is 90% complete interfaced but i am having hard time to identify the last two button switch.
They are behind a diode so i cant use multimeter. And the normal setup with ground on chassi and search on pins does noes not work either.
Do you have the pinouts for the button switches?
Br Peter
Can't you just simulate the fact that the bulb was replaced?  ;D
Haha actually it WAS simulated. Once i put some real 28V on it and wiggled the button it lighted up! :)
I was unable to remove the caps, only the square cover. Afraid to brake stuff so i hope these bulb will last a long time.
AFDS numbero uno completo!
Reeady for db contact soldering!
Quote from: kurt-olsson on February 27, 2021, 10:24:00 PMThanks Mick ill give it a try!
Br Peter
Contact me by PM, i can assist with the CMMs
My prevois button seems to be stuck. This popped out easily.
No wonder the lamps flicker.
This is old stuff!
The lamps has some kind of rust on them.
If they're just oxidized you could clean the contacts with an electronics cleaner (or very strong 90-95% alcohol cleaner) and q-tip or small brush. Clean the bulb contacts/bases and the contact points in the housing. Also, if it has a spring or a bent metal piece that makes contact, try readjusting them to make sure the tension is tighter against the bulb contacts...
100 new lamps is on the way! I think they need new ones anyway.
But thanks for the tip John.
Wait, you don't want any bulbs that have flown 1 million miles, nor mixed with a thousand mile bulbs, nor mixed with 2 brand new bulbs? LOL!
You gotta have one that needs a tap or two every now and then, makes you look like a real pilot...uh, or a poor airline mechanic ROTFLOL!
John  ;D
Haha could not find any used OEM 737 bulbs on ebay! Hahaha
@ 2k a pop for a new light assembly, a tap is well justified for an old assy. Airline mechanics are accountants as well didn't you know  ;)
