May 14, 2024, 08:11:05 PM
712 Guests, 0 Users
  • Online today: 762
Guests: 712
Total: 712
0 Members and 12 Guests are viewing this topic.
No more pressing "G" on the keyboard!
My Custom PCB that me and archen did is EPIC!
I have come a long way since i asked how to connect a single button on my MCP on the forum! Haha
The bigger panels will have two PCB in them.
Window heat panel 85% complete. Quite a challengevdue to the amount of Korrys and the tight space.
Still have problem with my PSU for backlight.
4-5 panels should not draw over 20Amps which is my PSU max.
My custom PCB still rocks. But tricky to solder, need a new solder machine. Fried a Teensy accidently.
Quote from: kurt-olsson on January 23, 2019, 12:19:24 PM
You sure have,  I am now going to have to start asking you for help.  This stuff that you have going on is utterly amazing now.  Nicely done I would say.  those panels look amazing.
Thanks Trev!
Would gladly like to help and give back something to the forum that helped me learn all this stuff. =)
#608
Overhead comes more alive by each day. Hehe
Problems right now: 5v PSU backlight (will add another PSU)
Can only connect two teensy on each USB output (will try couple of new pci-e usb hubs)
Full throttle!
Rerouting everything so it will have two db25 connector at the front instead of building in everything over the polyclutches, it was such a mess that way. Now i will build all components at the front of the throttle instead on a board.
Amp meter purchased!
24V Korrys + Overhead lamp (24v) with Light Test On = 2.95 Amp and my Power Source has Max limit of 3Amps so i guess its time for my second one! =)
5V backlight is only 4.7amps at the moment, more than 15amps to go.
I can really recommend an amp meter with "clamp" that you dont need to brake the circuit. Really nice and effective to use.
Positive rate.... GEAR UP! :)
Look and feel of this thing is just ridicoulusly sturdy!
And yes... this is a NG handle :)
757Simulator
Thanks Mike!
The nice interfacing is actually the previous owners work hehe
More power to the people!
back after a month of doing nothing to my sim.
solder two cables and connect to my teensy that handles the throttle which now gives me :
"Teensy did not respond to a USB-based request to enter program mode.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
I measured the Volts on it and it is alive and gives me a signal when connect but nothing in my Device Manager.
The cable works becuase i tested it on another teensy.
Nothing changed since last time except two tiny cables and the USB/Windows/Teensy hell begins...
Two hours of frustration, see you in a month...
And now it works again after 20 restarts and Auto-mode on the teensy loader...
This makes me crazy...
I need to find a stable USB setup fast...
Looks like i will have some slots for pcie usb cards! Haha
Gear panel installed with korrys!
Ok, some info that can help others.
If i plug my teensy into my USB-hub i have NO trouble uploading.
Hope that PCIe USB Hubs with powered hubs will be the ultimate solution for all trouble...
One more tip!
Dont use the Joystick stuff, much better to use datarefs...
Autothrottle is back online after like 2-3 years. :)
This will be my final setup.
Problem is, i only have 5 pins for
Trim wheel motors
Speedbrake servo
Trim indicator
I might go multiplex instead of adding another teensy.
Power hooked to the TQ
Once i connect my Gear handle i am able to perform Base Training! Yokes 100% complete, TQ 90% complete.
Overhead 35% complete.
Aft overhead 0% complete
Pedestal 0% complete
