Main => Builders Discussions => Topic started by: HondaCop on September 29, 2010, 06:45:09 PM
Title: MFD and display units
Post by: HondaCop on September 29, 2010, 06:45:09 PM
Does anyone know the sequence of how the displays are switched around, when using the PFD/DU MIP switches on the Cap/FO sides? Thanks for any info...
Title: Re: MFD and display units
Post by: NAX228 on September 29, 2010, 10:12:31 PM
MAIN PANEL DUs Selector
Selects what is displayed on the respective outboard and inboard display
units:
· Outboard Primary Flight Display (OUTBD PFD) – Displays the compact
EFIS format on the outboard display unit and blanks the inboard
display unit.
· Normal (NORM) – Displays normal EFIS and MAP displays on the
outboard and inboard display unit; provides automatic display
switching if a display unit fails.
· Inboard Engine Primary (INBD ENG PRI) – Displays the engine and
systems display on the inboard display unit and the compact EFIS
format on the outboard display unit.
· Inboard Primary Flight Display (INBD PFD) – Displays the compact
EFIS format on the inboard display unit and blanks the outboard
display unit.
LOWER DU Selector
Select what is displayed on the lower display unit.
· Engine Primary (ENG PRI) – Displays the engine and systems display on
the lower display unit and blanks the upper display unit.
· Normal (NORM) – Displays the normal engine and system displays on
the upper display unit and no display on the lower display unit;
provides automatic display switching to the lower display unit if the
upper display unit fails.
