Main => General Discussion Board. => Topic started by: NeoMorph on January 12, 2011, 02:34:23 AM
Title: Saitek Yoke - Sloppy Precision (Fixes)
Post by: NeoMorph on January 12, 2011, 02:34:23 AM
Is it me or is the Saitek Yoke sloppy when it comes to precision. Is there a trick to get more precision out of it.
I tested it out in FSUIPIC and found when it goes to center there is a huge amount of variation in neutral which means you have to have a large null zone. Part of me wants to rip out the guts and put in some better pots or something.
Title: Re: Saitek Yoke - Sloppy Precision
Post by: jackpilot on January 12, 2011, 05:10:26 AM
Hi Neo
There is a lot of info on this site.
A search on Saitek would tell you that these  products have  been questionned.
http://www.cockpitbuilders.com/community/index.php?topic=892.msg6946#msg6946
Post by: NeoMorph on January 12, 2011, 06:07:10 AM
Weird... when I searched I got no hits... Was half asleep when I posted lol
Well I read about how you mentioned the pots were inexpensive but when I opened up the thing I got a shock... My 360 joypad had better pots that these junk pots are. Get a £10 joystick and you will probably find the same pots inside.
NOW THE GOOD NEWS.
It shouldn't be too hard to actually disconnect the old pots and wire in new ones and then connect them to the Leo Bodnar 12bit board. What is even better is there is plenty of space to fit the LB board inside the yoke body. I will use the existing Pitch/Yaw pots for the throttle quadrant (after replacing the trim pots which is essentially what they are). I know I wrecked my warranty but tbh it will make the Yoke 500% better than what it was and the yoke is only a stopgap until I get my ATR 72 up and running.
I'll try and record the progress of what I have done and then post it on here when I have finished and report how good it is.
Post by: NeoMorph on January 12, 2011, 08:14:06 AM
Just found the idea Potentiometer for the Yoke...
http://cgi.ebay.co.uk/ALPS-Potentiometer-RK50112-10K-50K-100K-250K-RK50-pot-/350338636424?pt=LH_DefaultDomain_0&hash=item5191cf5a88
:eek:
Title: Re: Saitek Yoke - Sloppy Precision (Fixes)
Post by: NeoMorph on January 12, 2011, 05:27:40 PM
After messing about with the Saitek Yoke's innards I have come to the following conclusions:-
I'll probably be putting together an order for some parts this weekend as I also need some parts for another project.
Post by: mas55 on December 30, 2013, 10:31:57 PM
Hi john,
Have you done the mods you mentioned here?
Thanks.
Marco
