Main => Builders Discussions => Topic started by: jackpilot on February 27, 2011, 12:18:01 PM
Just a test but results are good.
LED strips on a piece of coroplast.
Orange film behind the keys.
Note, placement can be adapted but backlighting is already fairly even ( the digital camera picks up differences in intensity and color that are not noticable to the naked eye.)
Easy to make , took me 45mn.
Very Nice.
Thank you ...just sharing ideas.
:D
Jeeze Jack, those look awesome.. DId you just solder up the SMD LEd's yourself? What a neat idea.
Search Led strip on Ebay
15 feet rolls around $25
You can cut them by sections of 3 leds minimum.
Peel off sticky at the back.
Just need to link them when cut (green wire soldered + to + and - to - then apply 12v at one end.)
Any shape possible.
As long as you keep them about ½ inch away from the panel, backlighting is pretty even.
Thanks Bud, I will check it out.
Quote from: jackpilot on February 28, 2011, 10:08:06 AM
Any shape possible.
