Just stumbled across your site and saw that you're working on an interface solution. Just curious if this will only be catering to GA sims or whether it will/should work for any sim - DCS A-10C for example??
I'm building a pit for that sim and have been looking for a good & affordable solution to interface with my pit.
Here's a couple pics of what I've done so far... everything is still a 'work in progress'. :)
Not sure about the answer to your question but wanted to let you know that your panels look great! Looking forward to seeing photos of your progress. :idiot:
Thanks! ;D
Finding a good interface solution that won't break the bank has been the biggest challenge. I have very little electronics experience, so I am hoping to find as much of a "plug and play" solution as I can. Opencockpits offering is at the top of the list, I've just been holding out hoping something more suited for my skills would come along.
Quote from: pitbldr on March 30, 2011, 12:44:25 PM
Thanks! ;D
Then I would consider the FDS SYS boards...www.flightdecksolutions.com
Quote from: ETomlin on March 31, 2011, 09:53:48 AM
Those don't meet the "affordable" criteria. :(
They do if you count the time trying to figure out SIOC, or like really user oriented interfaces.
Turn on, move switch, select function and save......
Quote from: jskibo on March 31, 2011, 11:34:29 AM
Input for Input, Output for Output, the FDS boards are really about the same price considering S&H and ease of use, especially considering the customer support. However, being someone that can appreciate being on a *tight* budget, I can see how every dollar saved is tempting. However, just remember that building a sim is not really affordable for most folks and you sometime have to sit back and save up a bit to get the items that you really want, items that will save you headache and hair in the future. Just my 2cent worth :-)
Quote from: ETomlin on March 31, 2011, 12:05:35 PM
Good points guys. However, in looking at the InterfaceIT information, it appears it only works with FSUIPC. Don't know if I could even use those with the DCS sims.
Good point, unless you could use the mouse record action function in it....don't know if that will work with DCS though.
Unfortunately I can't answer your question but spot on panel work!!
