Main => Builders Discussions => Topic started by: Drewsta on April 04, 2011, 03:33:25 PM
Title: Cannot get th2go to work.
Post by: Drewsta on April 04, 2011, 03:33:25 PM
Hi guys , this is my first real post here and its a cry for help. I have come over to this forum as I believe the experience in here is at a better level for the help I need.
My problem is I cannot seem to setup the Th2go with my brandnew projectors. Wether i'ts a resolution issue or a software/hardware issue, I am unsure.
My setup.
Core I5 760 @2.8ghz
4 gig ram
2x ATI 5670 1GIG GPU'S
350gig HDD
Windows XP Home 32bit SP3
750 watt PSU
fs9 running LevelD767
3 x Benq 811ST wxga (1280x800) native widescreen projectors
th2go  digital edition
My problem.
I attached a DUAL LINK DVI  "cable with all the pins" To the 1st GPU and also to the TH2go box. I attached a usb cable from computer to the th2go box. Connected up all 3 projectors and started the computer. The middle projector shows the windows desktop, the left shows the benq logo etc, then nothing, the right keeps the benq logo up and says no sinal. I then ran the cd and loaded the software and followed the prompts. The computer reognised everything and gave me all the green ticks and asked me to restart. The computer srestarts normally nd the desktop comes up at 1280x1024 and looks good. The matrox software completes the install and says finished. I then right click properties and choose 3840 x 1024 for monitor 1, which says its the th2go on the ati5670. the screen changes and all projectors come alive and quickly say resolution 640 x 800 and all screens just have distorted horizontal lines across all screens and then i can't make out anything on the desktop. I also went to the matrox site and found that my GPU's can handle 3 x 1280 x 1024 resolution no problem and i have the green ticks from their software saying that its all compatible with my system. I have just spent close to $10,000 on this sim and the most important part I just can't seem to get to work.
When I first tried to set t all up, admittedly I was using a standard DVI cable, not a DUAL LINK. I am now using a DUAL link cable and it still doesnt work. I updated the matrox software from their site and that hasn't helped.
I am now lost. I have a 15000 dollar brown elephant sitting in my garage that I can't use and I can't tell you how heartbreaking that is right now.
If anybody has experienced this before or could perhaps shed some light on what I may be doing wrong, I would be forever grateful.
Thankyou in advance
Drew
Title: Re: Cannot get th2go to work.
Post by: jackpilot on April 04, 2011, 04:14:04 PM
Has to be a way...
Someone here will pop in.
We will make your Elephant a happy camper...
Guys..!!!
Post by: Drewsta on April 04, 2011, 04:51:04 PM
Thanks for the welcome Jack, nice to be here, I'm sure we'll bump brains and get it working somehow, I'm just slighly out of my depth now, so I am looking towards the SIMGODS for guidance.
Thanks again.
Drew
Post by: Nat Crea on April 05, 2011, 02:33:00 AM
GDay Drew its Nat here...
For a start , select 3840 X 800...no point selecting x 1024...selecting a higher rez
than your projectors is pointless and actually looks worse.
Second...I hate ATI...but thats my problem  :D
3rd...From memory in WinXP, you have to add 3840X800 to your Matrox config thingy box first (????)
Youll get it...
Post by: ivar hestnes on April 05, 2011, 03:23:59 AM
Yes, in the Matrox powerdesk software, there is a list where you can select up to 5 resolutions. The list is tricky to find, but you will find it when you search for it.
Set a mark for the 3840x800 resolution in that list.
Then you will be able to run your elephant at its proper resolution ;)
Post by: Drewsta on April 05, 2011, 03:58:36 PM
Thankyou for the replies guys. I'll try and change the resolution to that 3840x800 tonight. I do happen to have a "zotac"nvidia GTX275 and 8800gt that I could use for the sim instead of the Ati cards. Would they run the sim better? I'm guessing they probably would. I have always been an Nvidia fan, these ATI cards came with the computer. That may have to be my next move if this next step does not work.
Some good news though, my 747FMC arrived from FDS today and looks fantastic! I'll send some screenshots etc through when i can. Also 767 yoke from ace should be close now too!
I'll keep you posted on how it all goes.
Drew
Post by: Drewsta on April 05, 2011, 06:58:12 PM
Hi all, I just tried to set the 1280x 800 in the matrox setup and its not available? I checked the matrox website and it says the ATI 5670 is compatible and can have up to 3 x 1280x1024. Infact there is not much available to me at all. This is obviously where the problem lies. I have taken some screen shots to show you what i see.
Drew
Post by: carlos hermida on April 05, 2011, 07:54:00 PM
   Maybe  you can try this below as I had the same problem like you...
  I was never able to use my  Matrox TH2GO using those  DVI output or input connections for my setup  and the only way that worked for me was using all three output display connections with three  DVI to VGA adapters for outputs  and using the VGA input to connect to PC.
Then you only need to select the resolution that your displays or projectors  support in windows display resolution.
     It is working for me after that without any problem...
     In my case it only worked using VGA cables for all connections  but you can try first to use only the input vga to see if works....if not connect all with VGA cables and should work.
BR
Post by: Drewsta on April 05, 2011, 08:59:16 PM
Hey Carlos, I do have DVI-VGA adapters for all three projectors. I was under the impression that I needed a Dual Link DVI cable from the PC to the TH2GO box? I could try vga adapters on both ends of the Dual link DVI cable. That seems like a backward step though, im unsure.
Drew
Post by: ivar hestnes on April 05, 2011, 09:19:04 PM
Drew, it looks to me that you still have not found the list. None of your pictures is showing the list where you select up to 5 resolutions. It has to be done or you will not get your resolution. I think you need to look harder in the powerdesk software. The list is not so obvious to find...  I will make a screenshot later today if you still have not found it.
Post by: Drewsta on April 05, 2011, 09:30:01 PM
Ok Ivar , thanks , I'll go have another look
Drew
Post by: Drewsta on April 05, 2011, 10:04:15 PM
Ivar, I not sure wether or not I found your list but i did managed to save the setting somewhere so that it now appears in the box as you can see in the pics. Unfortunately it says that its not supported with my graphics card, yet the ATI HD 5670 has a Dual link DVI port?? Matrox website says that my graphics cards are compatible for that resolution.
Maybe I should be looking at putting in the Nvidia GTX 275 and 8800GT??
Drew
Post by: ivar hestnes on April 05, 2011, 11:53:38 PM
Hmmm... it looks like you have found the setting I was talking about, but not 100% sure.
But just discovered that you are using two gfx cards. How is these set up? SLI or is the computer running more than three screens? Could have something to do with it. You using teamviewer?
Sending a PM to you...
Post by: Drewsta on April 06, 2011, 12:19:52 AM
Ivar, yes 2 x HD 5670 not SLI/crossfire and running 3 screens only, as the captains panel has a splitter cable for the FO. I will download that software so you can have a look if you like.
Drew
Post by: Trevor Hale on April 06, 2011, 04:22:24 AM
Just one other thing to check Drew..  I am sure you have already checked this..
But With my tripple head to go, I remember that the matrox documentation made it explicitly clear that you use the cable they provide from the PC to the TH2go.  I know you stated that you have used a cable with all the pins, but I happen to think they have a propritary cable between the pc and the th2go.
Is there any way you can move the th2go to the pc, and use their short cable (that comes with) to test the unit?  I knwo that may be a pain in the a$$ but just another thought.
Post by: astron on April 06, 2011, 04:46:57 AM
Trevor is correct, if you are using a long dvi cable,you will get no signal on your monitors or projectors,i know this for a fact, i wanted to move the triple head to go,farther away from the computer and i used a regular 6 ft cable and had no signal but to one monitor, for whatever reason you have to use the short little cable provided with the triplehead to go and it works fine. good luck
Tom
Post by: Bob Reed on April 06, 2011, 05:35:12 AM
Sounds to me like Trevor is right. There is something that the TH2Go is looking for that is not present in a regular cable. It probably has to do with keeping the connection from the computer short so they are not working with a weak signal inside the TH2Go. My guess.
Post by: ivar hestnes on April 06, 2011, 05:43:50 AM
Have been helping Drew through teamviewer, and the problem was first that it was not possible at all to set the reolution through the powerdesk software. Only native "bios" resolution was working. After a software update, we successfully set the resolution.
So now the computer show the desktop correct in 3840x800. But to get it out to the projectors, the matrox cable must be installed. Looking fwd to see how it goes after he swap the cables  :)
Post by: carlos hermida on April 06, 2011, 06:26:10 AM
    So, that´s why I never was able to use my MATROX DVI input as my PC is connected 5 meters away from matrox . I never tried with the short matrox cable...  :o
    Ivar, do you think that I will note any image quality improvement using the matrox DVI input with this short cable?
Post by: Trevor Hale on April 06, 2011, 06:35:47 AM
LOL...  We all learn the hard way don't we?  ROFL..  Oh well..  if all else fails RTFM ha ha ha..
Post by: Maurice on April 06, 2011, 06:42:02 AM
If anyone needs long DVI-D cables (or other cables), here is a very good seller on e-bay with reasonable prices. I bought 25' cables from him and I am very happy with them.
http://myworld.ebay.com/cmplefree/?_trksid=p4340.l2559
Post by: ivar hestnes on April 06, 2011, 07:05:54 AM
Quote from: carlos hermida on April 06, 2011, 06:26:10 AM
    So, that´s why I was never able to use my MATROX DVI input as my it is connected 5 meters away fro my setup and never I tried with the short matrox cable  :o
Hi Carlos  :)
Well, if you have quality issues on your screens, it should defo improve with using the original Matrox cable. Even if it is short... (Size does not always matter, lol).
What kind of quality issues do you have?
Post by: carlos hermida on April 06, 2011, 10:33:58 AM
Hi Ivar,
   For now I am very happy with my visual setup using 3 x 32" LED tv's with resolution of 3840x720. Using this LED tv's it really shows  bright colours including real night flight feeling.What  I mean is that black is black at night and not dark grey colour as it was with my "old" 26 LCD from my first project.  ;)
   ...and back to my question, what I mean is if I use TH2GO DVI input I could see any improvement that really justify to review my VGA setup, of course using the same resolution.
I have done some quick tests when working on my visual setup testing VGA and then DVI and for my eyes I didn't note any visible improvement but for sure that have or they didn't had include this DVI outputs on all new systems...
I am  sure that running DVI D with 5040 will give the better image quality with this tv's but I am afraid about frames in FSX...
Post by: ivar hestnes on April 06, 2011, 01:17:02 PM
Carlos... you basically answered yourself here :)
If your image quality is crisp and you are happy, no need to do anything, but if you want to run higher resolutions, you need to change the cable and upgrade to DVI/HDMI cables all the way as the VGA will not do. Higher resolution = lower frame rates  ;) And higher resolution on relatively small screens, will not neccessary improve the overall quality afterall...
Post by: Drewsta on April 16, 2011, 12:47:18 PM
Hey guys, just a quick update to where I am at the moment. Ivar has been helping me with the Th2go setup and with some troubleshooting we have it up and running. Thankyou Ivar! The software did need to be updated and most definatelty use the cable supplied by matrox, alot of you were right about that one:)
I am very close now but still running into problems. I have the screens up, Fwdleft,Fwd,Fwdright and although not quite lined up, it's starting to look the picture. I will have to make some ajustments with the projectors and distance later. Warping wouldn't happen with the Fly Elise-ng warping software and after conversing with the guys there we may have solved that issue with a directx9c update, just waiting to see.
Before I do that , I need to fix another snag! Something very interesting is now happenening with my Leveld767 aircraft. When I have Fs9 in windowed mode I set the aircraft at the gate with aircraft cold and dark and save that flight. I click the battery switch on the overhead and watch the mip screens, i hear the audible click of the battery switch and see the correct parts of the panels on the mip come alive. I switch it off, they go off, all good. I then choose the top down view and over the top undock 3 outside views as discussed. I choose fullscreen view and it all spreads out across all 3 projectors and looks great (not warped yet though). Once again I click the battery switch and the mips show the battery is coming on and off still and the overhead is working properly, the flap lever makes the correct noises etc, all good because its all working as it should. The problem is when i save THAT as a flight either in windowed mode or fullscreen. I choose save flight, rename that scenario and save that flight. When I reselect that flight in windowed mode the flight comes up showing all the views on the forward projector. I have to select the mip panels and undock them and they fly away to their correct screens then I go to fullscreen. The views now go out to all three projectors and everything looks sweet. Now when i click the battery switch I hear the audible click and nothing happens! I bring up the overhead and it seems to be stuck in limbo or something. Buttons and switches work but their states don't change. The duct pressure gauge is frozen etc. If I reselect another flight from before without 3 undocked views it all starts working again. The panels seem to stop working after I save a flight with 3 undocked views.
Is there a procedure that i should be following when saving flights etc.?
Thanks again for your help guys, outstanding:)
Drew
Post by: Drewsta on April 19, 2011, 01:32:55 AM
Hi all, I might have a solution to this problem. I try a few things tonight and post the results soon.
Drew
Post by: Drewsta on April 20, 2011, 12:45:26 PM
Hi guys, I tried an idea i was given to cycle through the s key for views or hit the Shift + 1 key and that may make the leveld panels come alive. Unfortunately it didn't work. Something I did notice when I went to warp the screen and test what it looked like, Fly Elise-ng software also warped all my mip screens aswell? Perhaps i should just try 3 straight screens instead of curved wether that would make a difference.
Drew
Post by: Drewsta on April 20, 2011, 05:17:46 PM
Ok i have definatelty narrowed it down to the 3 undocked views. If I delete the 3 undocked views and hit ctl s to come out of top down view, the panels come to life straight away. The Leveld767 simply will not work for me with 3 undocked views, 3 x projectors and th2go. It will work fine with 1 outside view across all 3 projectors but that looks silly out the side. I have played with the warping software from Fly Elise-ng but that warps everything including all the instument panels.  :-\
Totally stuck again withh $10000 sim rotting in the shed.
If i had hair left i would have pulled it out by now.
I appreciate everyones help but i can only troubleshoot myself and keep trying the same things in different so many times i guess.
Ivar has suggested that I connect my pentium 4 to the coreI5 and run fs2004 and the levelD panels and aircraft from the p4 "server" and just the visuals from the CoreI5 "existing computer or client to be".
Drew
Post by: Drewsta on April 21, 2011, 08:26:05 PM
Hi all, I have it working thanks to a post I recieved on the 767 forum.
I followed this procedure and now can run everything properly on 3 undocked views in fullscreen!
A) Tired of reshuffling extra panles around on multiple monitors - I was, until I discovered this work around:
1. Load up FS9 & your favourite aircraft
2. Start a flight & go to a Windowed main panel.
3. Open up your extra panel windows, move them to your other monitor(s) and resize making sure you leave an allowance for the Windows frames which will disapear in full screen mode.
4. Save the flight!!!!! MOST IMPORTANT
5. Switch to 3d mode and check the position of your extra windows.
5A: Go back into Windowed mode (this appears to lock the full screen mode panel window positions into place. Then for the second time undock your extra panels and move and resize them into your extra monitor. THEN SAVE FLIGHT. This locks the windowed extra panels in place.
6. If you need to adjust, go back to Windows mode and CTL-C out of FS9 - DO NOT RESAVE THE FLIGHT.
7. Restart FS9 and the flight you saved (you should be in Windowed mode with your extra panels showing as you left them on your other monitor(s)).
8. Re-adjust your extra panels and then SAVE AGAIN, then recheck in Full screen.
REPEAT steps 6-8 until satisfied with positioning of extra panels.
9. When happy, kick off FS9 with your saved flight and go to full screen mode with your extra panels where you left them. Have a good flight BUT DO NOT GO BACK TO WINDOWED MODE AND DO NOT SAVE THE FLIGHT AGAIN.
10. At the end of every flight slip back into windowed mode and CTL-C out of FS9. Yes, the extra panels will resurface on the main panel window, this is no problem provided you don't save again.
11. Repeat the whole process with other aircraft.
I have noticed on one occassion that, on starting a flight in windowed mode, as you must to get this to work, the extra panels weren't showing. But, after pressing SHIFT + panel number they showed up on the second monitor as I had left them.
Caution: Remember that before leaving FS9 you must go into Windowed mode.
One thing remains, I need to check why my mip panels are still warping with the Fly Elise NG warping software, even with the warp child windows box unchecked. I'll get back to you on that one.
Drew
Post by: Nat Crea on April 21, 2011, 08:42:31 PM
Glad you have gone forward mate.
Believe me, no one here just fires up their Sim and flies...we all have issues :D
Post by: Drewsta on April 22, 2011, 11:26:15 PM
Thanks Nat , this hobby has really steep learning curves at times.
cheers
Drew
