Main => General Discussion Board. => Topic started by: Pilotgil on May 09, 2012, 11:33:38 AM
Title: New problem...Visual simulation is running SLOW. Seems like 1/3 speed.
Post by: Pilotgil on May 09, 2012, 11:33:38 AM
Help again,
Here what I mean. Say I'm at 200 knots flying low (100 feet). The airspeed indicator says 200 knots but when I look out the "window" the ground is going by really slow like 60 knots. Sim rate is 1X. Now this doesn't occur for all aircraft. My KA350 and Piper Seminole look correct. Everything else looks like it's crawling across the ground. Framerate is 50-65 FPS. My system is FS9.1, FSUIPC, WideFS.
Any ideas?
Title: Re: New problem...Visual simulation is running SLOW. Seems like 1/3 speed.
Post by: ivar hestnes on May 09, 2012, 11:44:47 AM
It actually sounds like your zoom settings is way off...
Post by: Pilotgil on May 09, 2012, 05:29:28 PM
That's IT! It was at 700 + !!!! How did that happen????? Thanks! Is there a place in some cfg file to set this?
Post by: blueskydriver on May 09, 2012, 06:36:19 PM
Search for Window Maker program and read about how it works, and then you will understand about the zoom factors, as well as the cfg file you're talking about...
BSD
Post by: Pilotgil on May 10, 2012, 10:36:46 PM
Thanks!
Post by: Pilotgil on May 11, 2012, 10:51:20 AM
Ok...I don't understand. First I'm using FS9.1 loaded with "FS" you name it on dedicated system that only has FS stuff and no internet, firewalls, etc.  It runs very well - about 60 FPS with every thing at max. I have two aircraft (KA350 and Piper Seminole) that the zoom settings are .35 (I have TH2GO on with three 42 inch LCD monitors). I match the windowed FOV to the physical FOV and that's where I came up with the .35. Works really good. However, if I select any other aircraft (Mooney, Cessna, etc.), the zoom settings are all over the place (0 to 700) and unchangeable and if you try, the sim crashes to the desktop. The keyboard shortcut will not reset it to 1 either.
I can't locate any .cfg file that seems to control this. Any ideas?
Post by: blueskydriver on May 11, 2012, 03:20:25 PM
Try this: load the plane that works and then save it as a new name like test plane save. Now, close FS9 and restart your computer. Next, start FS9 and load the file you just saved. Next, change only the airplane to the one that messes up. If it works, then you must start from a saved file first, if it doesn't work, then something is wrong with the aircraft.cfg and the camera.cfg somewhere to do with that plane.
You have to remember, once you setup the zooms they don't stay the same unless you load from a saved file name and not the interface window where you can select loaction, plane, time & day, and weather all the same time. Becuase that method will always use default zooms, so you use a pre-saved file, and then change the needed items via the menu line above.
BSD
Post by: Pilotgil on May 11, 2012, 10:15:54 PM
I gave the suggestion a try. After switching to a new aircraft from the "saved" to a newly selected plane, and if I try to change the zoom, FS crashes to the desktop. I took the aircraft file folder from a known good FS9 sim and replaced the crashing aircraft folder. Going back and trying the process again...crash. I should mention that the window under View Options does not show the visual field but only a black box...hence you know it's crashing...
Interesting is FS only crashes if View Options is selected! Otherwise she flies although it looks like it's going in slow motion.
Post by: hexpope on May 12, 2012, 06:49:16 PM
To be hoest, thats the first time I heard someone state a problem like that. If what BSD stated didn't work for you, then I would delete all saved files, and also the cfg file, and restart your simualtor. You will probably have to do some settings again in the display settings etc.
Also, another factor to point out, are you using any external settings with your graphics display driver for FS9 ?
Post by: Pilotgil on May 12, 2012, 10:39:14 PM
Except for the TH2GO driver. Nothing else that I know of. I may get brave and reinstall FS9; but since I'm only interested in the KA350 and the Seminole (and they work for some odd reason), I'll just hold off on that drastic move. Thanks everyone for the help!
