Im trying use the combined generator status (including APU gen) to control one output on a Outputs card. Im sure there has to be a relatively simple way to to do this.
The idea is, if all three generators are "OFF" then output 01 is activated. If any of the generators in FSUIPC are "ON" then output 01 will stay "OFF"
The scrip below is to give an idea of what I want, but Im not sure how to make it work as I described. Any help is greatly appreciated.
Justin
Var 22, name gen1pow, Link FSUIPC_INOUT, Offset $3B7C, Length 4 // GENERATOR 1 STATUS
Var 23, name gen2pow, Link FSUIPC_INOUT, Offset $3ABC, Length 4 // GENERATOR 2 STATUS
Var 24, name APUpower, Link FSUIPC_INOUT, Offset $0B51, Length 1 // APU generator active flag
IF &gen1pow = 0 // Generator one off
If&gen2pow = 0 // Generator two off
If&APUpower = 0 // APU off
&AC_Relay = 1
ELSE
&AC_Relay = 0 // AC master relay in normally closed position places 737 AC power to "ON" status
Var 25, name AC_Relay, Link IOCARD_OUT, Output 01 // Master AC relay K1
Justin
You are very close <g>
I am just about to call it a day here and also after a few beers!
All you need to do is to add some curly brackets to each nested IF statement and you are there. Give it a try!
If still a prob, then say so and I will post the solution tomorrow <g>
Hello,
That how I first tried it but the output only responds to the last offset (APU) and ignores the position of the first two generator offsets.
I tried some other arrangements but also had no luck.
Justin
Justin
You need to nest each IF statement as below
IF gen1 = off
IF gen2 = off
IF gen3 = off
relay = on
ELSE
relay = off
That is how I first tried it, but no luck.
Justin
Justin
I see the problem. The logic is correct but the code will only run when the variable it is attached to changes value
I will change the code to a subroutine and repost
Justin
Apologies, the logic was incorrect. If all generators were off it was ok, however, if gen1 was off and gen 2 was on, then it never ran the code to turn off the relay. It did not get to the ELSE command as it had already partially run the sequence of IFs. I learnt something, so it was a useful exercise :)
Here is the code that works
Var 0 Value 0
&check_state = 0
&check_state = TIMER 1 0 5
var 1 name gen1
var 2 name gen2
var 3 name gen3
var 4 name relay
var 5 name check_state link subrutine
IF &gen1 = 0
IF &gen2 = 0
IF &gen3 = 0
&relay = 1
ELSE
&relay = 0
ELSE
&relay = 0
ELSE
&relay = 0
I have introduced a TIMER that never stops and calls the check_state variable every 50 milliseconds. The check_state variable then polls the generators condition.
Thank you, Ill try this in the sim this morning.
Justin
There is another way that I used to do a similar function in my sim that I think might be easier and cleaner? Since the Gen on/off is a true/false statement, i used the C0, C1, C2 functions. Works well and easier to use in cases like this.
You are correct. It was just that I started off trying to keep to roughly the same logic as Justin had used. It did not work :(
The road to hell is paved with good intentions :)
David,
It works perfect! Bingo! I think interfacing the overhead has made the engine start become the most interesting part of the 737 project.
Im happy I can use only one output controlled all three generator switches. Below is how the script looks as I used it.
Var 300 Value 0
&check_state = 0
var 301 name gen1AC, Link FSUIPC_INOUT, Offset $3B7C, Length 4 // GENERATOR 1 STATUS
var 302 name gen2AC, Link FSUIPC_INOUT, Offset $3ABC, Length 4 // GENERATOR 2 STATUS
var 303 name gen3AC, Link FSUIPC_INOUT, Offset $0B52, Length 1 // APU generator active flag
var 304 name relayAC, Link IOCARD_OUT, Output 01 // Master AC relay K1
var 305 name check_state link subrutine
IF &gen1AC = 0
IF &gen2AC = 0
IF &gen3AC = 0
&relayAC = 1
ELSE
&relayAC = 0
ELSE
&relayAC = 0
ELSE
&relayAC = 0
