Main => General Discussion Board. => Topic started by: muffyman on August 10, 2013, 03:19:25 PM
Hi fellow cockpit builders I have a Flightdeck solutions MCP the model FDS-G1 which is one of the first models put out by CPflight for flight deck solutions, it was designed to run with project magenta, I have made inquires with both companies but they don't know, could anyone tell me if this model can run with any other avionics software, project magenta is to pricy for me many thanks in advance cheers Ian
Ian,
Not an issue of "not knowing"....
It was released back when PM was the only game in town...
Any other platform you might be thinking of was not likely on the market....
We also had a G2 that was around a bit longer, it was using the same driver so watch for G2 and cross your fingers, you might get lucky...
Peter
