Main => General Discussion Board. => Topic started by: Aerosim Solutions on September 30, 2013, 06:57:04 PM
Title: Cheap map lights
Post by: Aerosim Solutions on September 30, 2013, 06:57:04 PM
Hi all,
I have just made a couple of map lights to go with my newly acquired eyebrow trims. I bought a pair of $9 LED flashlights and basically cut them in half! I made a gimbal bracket so they can be aimed anywhere when they are mounted. I soldered wires to the battery contact tabs and fitted a simple connector block for the 3Vdc power supply. The torch button still works and they look close enough, a cheap solution!
[smg id=996]
[smg id=997]
Cheers Gwyn
Title: Re: Cheap map lights
Post by: Karl737 on September 30, 2013, 09:20:20 PM
Brilliant!! (pun intended) ;D
Karl
Post by: glooker on September 30, 2013, 10:48:57 PM
Gwyn,
That is a great piece of work.  Simple and elegant.  You have Inspired me to make my own.
Greg
Post by: Aerosim Solutions on September 30, 2013, 10:56:28 PM
Quote from: glooker on September 30, 2013, 10:48:57 PM
Gwyn,
Greg
They are Arlec torches Greg, I got them from Bunnings!
Cheers Gwyn
Post by: jackpilot on October 01, 2013, 05:02:45 AM
Good idea Gwyn
I used some also for the side map. ($3)
I feed them 5v from the OVH PSU with a resistor.
Post by: sagrada737 on October 01, 2013, 06:29:01 AM
Nice work on the Map Lights Gwyn!  I always am inspired by your innovation.
Have you done anything similar for the light on the upper part of the Fowward Overhead, which illuminates the Pedastal area?
Post by: Aerosim Solutions on October 02, 2013, 12:49:10 AM
Quote from: sagrada737 on October 01, 2013, 06:29:01 AM
Hi Mike, I haven't got a roof structure yet!!
Cheers Gwyn
Post by: wildcat02 on October 02, 2013, 10:49:34 AM
For the OVH I used the head of a small desk light.
http://www.flightdeck737.be/hardware/fwd-aft-overhead/samenstelling-en-onderdelen/ (http://www.flightdeck737.be/hardware/fwd-aft-overhead/samenstelling-en-onderdelen/)
I've built the' map lights' with parts of plumbing, a lamp holder and a LED lamp.
http://www.flightdeck737.be/pc/electronics-2/map-lights/ (http://www.flightdeck737.be/pc/electronics-2/map-lights/)
To give an another idea ... ;)
Clement
