Main => Builders Discussions => Topic started by: dc8flightdeck on February 12, 2014, 03:30:46 PM
Title: report, using panel mount intercom
Post by: dc8flightdeck on February 12, 2014, 03:30:46 PM
I now have the 6 position panel mount intercom completely interfaced. This intercom has a music fade feature on the "music in" jack.
To make it compatible with pilot edge, tonight I cut a stereo audio cable for the computer and wired it direct to the intercom mic wire that normally connects to the aircraft's com radio.
It works great! It really amped the PE audio coming from the computer.  Up until now I always placed the computer sound into the intercom music in jack which leaves the PE audio a bit low on any intercom Ive tried. Connecting it to the intercom mic radio wire took care of that problem, i actually had to turn down the intercom volume.
I put an mp3 player on the "music in" jack and the music fade feature works perfectly. I talked to a PE controller and he didnt have a clue there was music playing on my intercom.
This is my first attemt to use a panel mount intercom and Im thrilled with the results. it took time to install all the wires but I didnt have to worry about using expensive extension cables.
One other thing, I wired both of the overhead 737 speakers to one intercom headset wire which also turned out well. Thankfully those speakers are amped.
Title: Re: report, using panel mount intercom
Post by: fsaviator on February 12, 2014, 10:09:33 PM
Very nice.  Could you share a diagram, if it's not too much trouble?
Post by: dc8flightdeck on February 13, 2014, 12:25:59 PM
Well, I have the diagram that came with the intercom, but have no way to scan it...
