Main => Builders Discussions => Topic started by: jackpilot on January 13, 2010, 05:27:23 AM
Hi Captains
What is the proper sequence of announcements with the GPWS test button.?
I make it work by recording a wave regrouping the various sounds (hence the question above) and reassigning the door open/closed keyboard command to that Wav. and to the Test button. I use Posky 737-700 and it has a door Wav. that I do not use.
Asking again... :huh: ;)
LOL.. I wish I could answer this.. but Alas, I am not sure of the answer.. Sorry Jack.
The 737 has a short GPWS test and a long GPWS test.
I have both as a WAV file for you if you wish.
Stef
Thank you Guys.
Stef , check your PM.
Found this too, on a tip from David Allen.
GPWS Test Mode (http://www.youtube.com/watch?v=LXEgmyE_iG4#)
From that video I made this wav file with PMsound waves..not perfect copycat but can help. Stef sounds must be better.
Files are on their way. Nice clean soundfiles, no ambient sounds.
Stef
Got them..thank you very much.
May sound stup. but how do you converts MP3 to Wav? :huh:
oops...told you they were wav's but they are mp3's sorry.
There should be converters around. I'll see if i can find one.
Stef
These should do it:
http://www.convertmp3towav.com/ (http://www.convertmp3towav.com/)
Stef
