Main => Builders Discussions => Topic started by: Masterploxis on October 23, 2016, 09:43:59 AM
Hello,
i run P3D via 3 Projectors, Curved Screen, TH2Go etc...
Problem: When i load a flight the 3 separate windows are running though the projectors. Is there any way to have the menu of P3D positioned at a separate monitor ?
I have the problem using Immersice view, that when i want to open the p3d menu, that it is shown on the most left projector and cut of a little on the top. What i require is, that the game menu (options, views etc.) is shown on the small separate monitor i run beside the Th2Go...
Any advice ? I added a nice ms paint for explanation....
Andy
Hi Andy,
I have a similar setup, and the same question. I too would like to run a separate smaller monitor with P3D running on the curved screen. Hopefully someone will offer a solution.
Is there a way that you could use a host computer that has a remote login software package such as TightVNC running. Then just remote into your other computers.
That is how I do it. But you would need to have desktop warping turned on with Immersive Display with this approach.
Run P3D in window mode not full screen, assign all programs to open on the small screen, (separate monitor) after that all you need to do is doble click on the top window bar of the running simulator to switch screens.
Before closing the simulator make sure is back to the small screen otherwise it will open back on the large screen.
Hopes this helps.
