Main => General Discussion Board. => Topic started by: RayS on February 02, 2017, 10:17:47 AM
Title: Congratulations.. It's sort of a Beech Throttle Quadrant...
Post by: RayS on February 02, 2017, 10:17:47 AM
The 1900D Throttle replacement project is under way. Plan is to use a Teensy Microcontroller for all the joystick axis and Aileron/Rudder/Elevator trim. The Carenado 1900 has a bug in that using reverse thrust only zeros out the prop blades and reduces the throttle to 0. What should happen is the prop blades to to full reverse and the engines spool back up to X%.
Interestingly, the bug doesn't manifest when you use a 2d cockpit view. It only is an issue with external hardware.
Title: Re: Congratulations.. It's sort of a Beech Throttle Quadrant...
Post by: navymustang on February 03, 2017, 02:31:47 AM
The quadrant looks great. I have built a 1900 with the same software, now I need to go look at the reverse behavior to see if I am experiencing it also.
