Main => Builders Discussions => Topic started by: lesdawson on September 19, 2017, 01:22:52 PM
Title: Help needed with flap lever base on sairek
Post by: lesdawson on September 19, 2017, 01:22:52 PM
Hi all,
As part of my cockpit I have l taken apart a sairek
Throttle and yoke and used the throttles as they are
With a bit of cosmetic work, then I used the X axis potentiometer for some home made rudder pedals.
Which work well
I cut three wires to the y axis potentiometer, used the
Pot in a home made flap lever (photos to follow when I figure
Out how to post them!) But now I have reconnected
The wiring, I'm getting no response from it.
Once it was wired up, I loaded up fs2004 and opened fsuipc
But in the axis tab I get no response when moving the
Potentiometer.
The wires were very simple- yellow, red and black. And all
Wired back up the same. Multimeter shows the pot is working ok, I have tried checking all connections and can't really think of anything else...
Anyone got any ideas???
Thanks in advance
Title: Re: Help needed with flap lever base on sairek
Post by: Bob Reed on September 20, 2017, 04:04:12 AM
First simple question, have you calibrated the axis in your operating system? Does it show and work there?
Post by: lesdawson on September 26, 2017, 11:24:10 AM
You were right to suggest calibration and simple solution,
After a couple of re-boots it's now working....
Still needs recalibrating quite a bit....
I think I may not have completely shut down the pc and
Re-started when I first connected it.....
