Main => General Discussion Board. => Topic started by: mdavenport on September 23, 2017, 12:36:42 AM
Ive obtained a sismo fwd overhead and am looking for ideas on how to mount this.
My sim is in my loft with a pitched roof so I need to fix this from the rafters as I don't have a cockpit frame.
I was thinking of hanging down 4 braces and fixing these to the 4 screws around the sides of the overhead.
http://m.builderdepot.co.uk/speed-pro-600mm-heavy-duty-restraint-strap-twist-at-100mm-galvanised.html
However whenever I look at cockpit frames, overheads seem to be fixed on their back. Is there a reason for this.
Any suggestions on how I should do this?
Mark, Claus Hansen has his attached to his roof. Take a look to his site if you haven't already. He's always willing to help out as well.
https://www.737sim.dk/ (https://www.737sim.dk/)
Simple reason for swinging mounting - you eventually will need to open and access the overhead for some maintenance. Even if that's "turnkey" solution from Sismo or any other company.
(https://lh3.googleusercontent.com/k5V8XSqwaNpmHV2RoYc3BsOE_t6OSJOe40M3JE5zPEAUsRSxJ4FiZEcKAgUfVymCrJCw0_FOfQfXXM5zyc0AJXARxTlF_ga6Apx-acNfqgoX5BkFbi7bY4QINzEw2M1I-geY6L_SWqoKlGzEFUpUWocghUXJCpEo2Ec2Al1ZxRm9nTimzc_Nta61tTTIc9hxf8qfzoqX2E2u-hTaEPFKgZhMeqbsLm2uQ8DRaOf84HcmYHiciLsNXw5lqQfLhEdjSSz0Q-NDAIsG4k19ZR5TAOgbOShXnLevy5hw5k8jM-S3syhB4a1hc8qB0M8dIj9CAJLL215KHUroum9sUjuGz1f-c__7N41KglODzhz95VBlku-USwqX9tbdOpkS5Q-EFUWnNCWfp0M6nBOs9JRxuMGFWUXjSXUMYY6pkt3KMRIfyqCOVlU_FDvBZmqgmO0ZSs7YSkuDfCTmegEzAWxz7HfphE0rXuD3c0toYoLaoQQ-AT6rSmwrRSwLIKT63oU6E99LOtdZtCAgeOTLa2tBIOErd_P13qADZz1toQur6K5E2MHNdfsiWntbvqJ8256kfJXo=w1379-h1034-no)
see my overhead for example:
http://elephantair737.blogspot.ca/p/overhead_13.html (http://elephantair737.blogspot.ca/p/overhead_13.html)
Quote from: Flying_Fox on September 24, 2017, 09:03:19 AM
Agreed, you will at some point want and need to open it. Very important to have access. Think a head and build it in.
