Main => General Discussion Board. => Topic started by: kurt-olsson on April 27, 2018, 09:03:57 AM
Title: Input on my measurements
Post by: kurt-olsson on April 27, 2018, 09:03:57 AM
Hi
My MIP is spot on in height according to Marcuspilot. 61cm above cockpit floor.
But the MCP is around 102.3cm from the floor. According to Marcuspilot this should only be 99,5cm.
The problem is that my MIP and MCP has exact 90 degrees in relation. So my only option as i think is that i tilted the MIP panel to far back, but i made it 15degrees of angle.
Any thoughts and what are your measurements on these positions?
Title: Re: Input on my measurements
Post by: paulnd on April 27, 2018, 09:32:29 AM
Do you have your screens yet or at least their measurements and a plan to mount them?
I found this to be the most challenging part and suggest that you build your MIP around the screens rather than complete the MIP structure and then try to get the screens to fit.
:2cw:
Paul
Post by: kurt-olsson on April 27, 2018, 09:41:40 AM
Your totaly right and i am going to have to disassembly the mip for this. But my plan is to have everything modular so i can remove parts when needimg to fix stuff
