Main => Help and Support => Topic started by: Xpress690 on October 10, 2020, 07:46:11 AM
Title: PFC Avionics Rack
Post by: Xpress690 on October 10, 2020, 07:46:11 AM
Hi all....
I Will like to ask for some help, sorry if this has been talked about on other post.
I´ve got a PFC Avionics Rack that is running with XPlane11-11.50 Vulknan and MSFS2020. All is good and all works fine with the exception of the bottom part of the rack (the GPS and Alt Pre-Select buttons) that I can´t find a way to program them. Thank you for your time anda all the help you can provide.
From the Azores..... happy landings
Paul
Title: Re: PFC Avionics Rack
Post by: Trevor Hale on October 10, 2020, 09:17:05 AM
Hi Paul,
Have you tried these with an older version of Flightsim?  Maybe P3D V3 or the 32 bit stuff?  Or do you think you have a hardware issue?
I myself am still having issues getting all my stuff to work with 2020.  I have never been an X-Plane Guy so I can't comment on that.
Post by: N4208T on October 12, 2020, 05:45:47 AM
PFC does have a set of downloadable utilities.  Have you tried that?
Steve
Post by: N4208T on October 18, 2020, 07:43:59 AM
I found those utilities if you would like a copy.
Steve
Post by: Xpress690 on October 28, 2020, 03:27:21 AM
Quote from: Trevor Hale on October 10, 2020, 09:17:05 AMHi Paul,
Hi Trev (canuk
Hi Trev (canuk??)
Got most of the rack working with the exception of the GPS buttons (NAV-WPT-FLP-CALC-AUX and all the other buttons) as the Altitude PRE-Select....
I´m mainly a small plane pilot and it´s nice to have all the control of the plane with in reach instead of have to go on the screen with a mouse and do the changes you need. I would like to have a way of programming the darn things and be happy..
Thanks for the response and will let you know if anything changes.
From the Azores....happy landings
Paul
Post by: Xpress690 on October 28, 2020, 10:31:19 AM
Quote from: n4208t on October 18, 2020, 07:43:59 AMI found those utilities if you would like a copy.
Steve
Thank you so much...
I just don´t know what to do with all of that, but thanks anyway..
paul
