August 28, 2026, 04:36:38 AM
212 Guests, 0 Users
  • Online today: 390
Guests: 212
Total: 212
Environment wave.
Started by jackpilot, December 29, 2010, 05:07:13 AM
Hey Guys
My 737 sound file contains a wave called Environment.
Plays a nice buzz-wuzz-fan-whatever "ambient" sound, on top of the PM sound"Avionics" when the aircraft is parked with systems running before engine start.
Problem: there is also a bass rumble in it which plays too loud with my sound system woofer and ruins the effect.  ???
1) would you have a nice wav that I could try for that purpose
2) would it be possible to edit my wav and cut the rumble.?
I'm no expert at that.
may be a daft idea but cant u have the woofer only switched on when the engines are also on?
Hi Jack. I spent a fair amount of time working with NicD on a sound set which I am still trying to find. If I find it I will send it over. If you want to try and edit the wav file you have all you need is a sound program that will let you adjust the tone and remove all the bass from it, save it and give it try. Of course, before you change it make a backup so if you don't like the results you can start over.....
CeeGee
Jack, I put up a zip with 6 alternate cockpit background sounds. One of them might work for you. I hope that this helps, Charlie.
Charlie I have a big problem with your wav files...
Choosing one!!!    :laugh:
Thanks a ton, Good work.
