October 19, 2026, 11:57:12 PM
395 Guests, 0 Users
  • Online today: 1,093
Guests: 395
Total: 395
Windows7 INI files - saving issues...
Started by sagrada737, January 14, 2014, 08:38:09 AM
Hi Folks,
I ran across an issue saving config.ini files in my flight model application that may be an issue for other folks as well.  In my case, this involved making necessary changes to an application INI file in Notepad, and then using the Save function to save the file.  The problem was, it did not actually save the changes that were made to the INI file.
It turns out that using the SaveAs function to save the INI file does indeed save the changes made to the INI file.
This is most likely due to "Permissions" issue within Windows.  So...  If you run across this same problem with your Sim applications, just use SaveAs to ensure that changes in INI files are correctly saved.
