January 14, 2026, 06:26:52 AM
805 Guests, 0 Users
  • Total Topics: 7,895
  • Online today: 1,038
  • Online ever: 1,956
Guests: 805
Total: 805
P3Dv4 Multi-Display Performance?
Started by FredK, June 05, 2017, 04:44:56 AM
Bump on this:
Anyone have anything to report on how well P3D V4 runs on a multi-display setup (single computer) versus V3?
As a multi-channel (WideView) user for almost 15 years now I am on the verge of making a decision to bite the bullet to invest in the best rig possible at this point (Titan 1080 water-cooled GPU for example)to run my multi-displays off a single computer.  The thing is I will be very disappointed if it does not at least approach the display performance of what I have running 4 computers (server + 3 clients).   I am not looking to exceed....just to match, or nearly match. I know that P3D V3 is well short of that criteria.
It is been hard to glean that understanding context from the forums to this point. In any event I will most likely spec out and put my order in for the hardware this weekend and find out firsthand.
Support for WideView appears to be dead going forward, and I do not want to be stuck on V3 in any event.
yup works brillent i running x4 1080ti single computer
Fred, I cannot comment for v4 but I will tell you that on 3.4 I have run 3 displays with multi views off one computer and video card with full orbx scenery, most sliders all the way up, and active sky with Rex textures and mine ran like a raped ape.   I have the 7700 kaby lake overclocked to 4.2 which I think is one of the most important things needed.   32 gig of memory (not as important of course on 3.4 but probably a big deal on v4), and a EVGA 1080 GTX with H110 cooler.    I think it would be interesting in v4 to try with dual 1080 ti's.   Theoretically one should be able to run 5 displays.
I will likely try out P3D v4 once Pete has FSUIPC updated (havent checked to see if this is done yet).
Right now XP-11 is still my primary goto.
QuoteFred, I cannot comment for v4 but I will tell you that on 3.4 I have run 3 displays with multi views off one computer and video card with full orbx scenery, most sliders all the way up, and active sky with Rex textures and mine ran like a raped ape.   I have the 7700 kaby lake overclocked to 4.2 which I think is one of the most important things needed.   32 gig of memory (not as important of course on 3.4 but probably a big deal on v4), and a EVGA 1080 GTX with H110 cooler.    I think it would be interesting in v4 to try with dual 1080 ti's.   Theoretically one should be able to run 5 displays.
Scott -
Is that 3 windowed views using ViewGroups or a single stretched view?  My interest would be the windowed views which tax performance but avoid the fisheye issue.  I assume you are running 1900x1080 displays.
Also, from what I have been reading dual GPUs may actually make things worse in a CPU bottlenecked config.
I am just trying to understand all this as I have no multi-display experience outside of WideView.
Quote from: FredK on June 06, 2017, 03:18:51 PM
Scott -
This is windowed views using viewgroups.   Each screen is 1920x1080.   I am not in front of it right now but I believe I have each at 50 degree and have at 3 differnt angles.  Not the single surround view at 5760x1080 with fisheye.   I can only assume performance would be even better on P3D v4.
Here is a video taking off out of KSFO with my Sim in P3D v3.4.  Orbx Global, Vector, And Northern CA scenery with Active Sky2016 and cloud art.   Single 1080 gtx and 7700 processor as mentioned above.
https://www.youtube.com/watch?v=fCxgOvH5ziQ&sns=em
Not the best video to show off the viewgroups but I could make another showing whatever you want.
