October 16, 2026, 11:17:04 PM
447 Guests, 0 Users
  • Online today: 1,050
Guests: 447
Total: 447
Real Boeing 737 yoke handle wiring
Started by Aerosim Solutions, June 09, 2013, 05:48:13 PM
737man
Gwyn, do you know the voltage for the 3 switches?
I assume 12V?
1   ELEVATOR TRIM
   Boeing wiring harness colors   Simulator Function        Comments
   White/Red                                Common
   White/Orange                           Trim "Down"
   White/Black/Orange                  Trim "Up"
   White/Violet                             *Not used*        Makes with White/Red - both directions
2   PTT ROCKER SWITCH
   White/Black/Brown                       Common
   White/Grey                                   Intercom                     Bottom trigger
   White/Red/Black                           Mic                              Top trigger
3   AUTOPILOT DISENGAGE (3 pairs)
   White/Blue + White/Black/Yellow       A/P Disengage               Normally OPEN switch
   White/Yellow + White/Green             *Not assigned*              Normally CLOSED switch
   White/Black/Green + White/Brown    *Not assigned*              Normally CLOSED switch
Voltage should not matter, as 90% of IO cards inputs are grounded to switch them.
These switches are all rated at a minimum of 28v, so any IO card will work fine.
737man
ok..Does anyone know where  the mic & intercom prosim assignments are?
Caflyt
Lance,
I would be very interested if you could post a schematic of your wiring here as I am completely confused on the PTT wiring.
I also want the intercom and Transmit functions separated in Prosim.
Any chance you could sketch out a diagram of your yoke wiring when completed????
Craig
Quote from: 737man on June 23, 2017, 11:03:50 AM
There aren't any.  Prosim does not handle radio transmit or intercom functions as FSX/P3D does not either.
You would need to use Vpilot/SB/FSInn etc  or other 3rd party software / hardware for mic transmit & intercom
