June 15, 2024, 07:54:11 PM
144 Guests, 0 Users
  • Online today: 218
Guests: 144
Total: 144
Congratulations!   It's always great to realize success in getting things to work.  You might try using a window tinting film, that is about 30% gray, to reduce the glare on the display, which will also result in improved contrast.
Thanks Mike.
Yeah i am adding some kind of film to cover the hole and make it look more like the real thing. :)
Now with plastic covers of the displays
If not having a custom pcb, the wiring is going to be a mess.
This is just total crap! But i will just install it, put the lid on and forget about it...
5 switches to go...
almost there...
Thanks Jack.
Thats my confort regarding the cable "rat nest". At least it looks good and it works =)
Do not bother about the Spaghetti bowl (now)
One of these days you'll decide to make it nicer... because it will bug you since day 1.
We have all been there, done that, :D
Left EFIS rewired.
Shoukd rename from EFIS to PITA. Pain In The Ass!!!!!
Compact little Unit...
Quote from: kurt-olsson on December 05, 2020, 11:52:49 AMMcp solid as a rock!
Kurt, wouldn't you prefer if the numbers changed sometimes?  ;D  8)
Only joking, Stirling work my friend.
After like 7 years of building i finally made the jump on a 70" tv that will go in the front!
This will be a big jump from a 23" monitor on the side! Hahahahaha
Tonight is the night...
Boys turn i to men...
Linups becomes takeoff clearances...
Pregnant women gives birth...
My 70" TV is going upp the wall!!!
Fabulous, but I bet your second thought was - I need just two more  !
Quote from: navymustang on February 06, 2021, 06:58:13 AMFabulous, but I bet your second thought was - I need just two more  !
Hahahaha!!!!
It was EXACTLY my thought!
Yeah , i was satisfied with my tv. But i also was able to realise just how badass it would be with two more!!!
When sidewalls and a solution for my ipeco chairs is done. I am getting two more! :)
Finally up with the clouds after 7 years build with no monitor!
https://youtu.be/3IRnA4ttk8I
Cruising with me Boeing!
Have anyone of you noticed a segnificant FPS drop on ZHSI when using all displays?
Just CPT side and it is smooth as a kitten but if i add ECAS then half the framerates. X-Plane is not affected at all by this.
Have gotten alot of things completed lately!
My TQ is almost done 100% except the Trim and trim wheels.
Good to be back with soldering db connectors! :)
