737-200 overhead build
Started by ElStino737, January 09, 2017, 06:41:09 AM
Yes, i have used Allied, good to deal with.
Also most of the major electronic suppliers like Digikey, Mouser etc are good for these.
One place i strongly suggest you avoid is Bulbtown.
I tried to order from them 3 times and each one was a complete disaster.
B747-400
Thanks for your hints  8)
Hans
Hans G. Schuetz
http://B747-400.net
ElStino737
Quote from: B747-400 on January 15, 2017, 11:52:05 PM
Hi Stijn,
I'm in the same boat like you ... I need bulbs for my B747-400 panels. I found another source:
http://www.alliedelec.com/wamco-inc-wl-6832as15/70117647/
More or less same pricing!
Does anybody has experience with this shop?
Hans
I ended up ordering them there. I'll let you know how they are.
They also have the bulbs for the korry's. needed them too.
B747-400
Excellent.
I think I will order from Diki-Key .. they are in Europe as well.
Need to check the number of bulbs ... I'll keep you up to date about Digi-Key too!
Hans
Hans G. Schuetz
http://B747-400.net
ElStino737
Quote from: kurt-olsson on January 10, 2017, 01:43:11 PM
I use a uln2803a driver. That is what i use for my korrys. Paralell the pins and you can drive 2amps through one chip.
Use analog output on teensy.
Got that working now, however, the Korry's in these OEM panels are wired up with a common ground and this chip is assuming common +, not a problem with type 2 Korry's, but in type 1 Korry's the internal diode is preventing the light from coming on.
Am I missing something here?
