June 15, 2024, 05:51:36 PM
199 Guests, 0 Users
  • Online today: 218
Guests: 199
Total: 199
0 Members and 13 Guests are viewing this topic.
WOW JACK! That puppy looks so nice, glad you got it setup Plus, it's awesome still seeing you tearing OEM things apart...post a video once it's up and running.
Hey Everyone,
Update for my sim, I pulled out the SimKits USBGauge that's been working for 10 years. The servo sort of went bad...it was moving, but inaccurately; good thing I had another HiTec HS-311 Servo on the shelf...lucky me...lol!
Only issue I had was re-installing it, since you really need 2 people, one to hold and one to insert the screws. However, got it in with a clamp and some patience; well, the patience only came after a dozen curse words from dropping it beforehand. Good thing I didn't break it right after just tearing it a part; maybe, I just got lucky again.
What's that saying "good or bad luck comes in 3's" Hopefully, that's the case for me tonight with having the right servo and being clumsy by dropping the thing without breaking it. Whatever the 3rd luck item will be, I'll happily take it. Offsets all those bad Gremlin nights throughout the years...
A cautionary tale: installing MSFS2020 on a system with FlyElise warping software.
I have Microsoft updates completely disabled so my copy was still on v1809.
To install from the Microsoft store I had to update windows.
Lovely....
After getting all the latest updates installed I discovered that the Warping software was now inop, requiring an update to FlyElise as well.
My copy was an older copy (if it works, don't fix it!)
I was well beyond the support terms for an update to the warping software so I had to renew it to the tune of $251.00 US.
It took a few hours to exhaust my supply of swear words which is a difficult task in itself; having served in the Marines I have quite an extensive vocabulary.
Sometimes I forget that this is an expensive hobby.
Quote from: RayS on August 29, 2020, 05:05:19 PMSometimes I forget that this is an expensive hobby. Microsoft will (stitch you up like a kipper) every. single. time.
I am only going to add my 2 cents once . why is it mostly everybody is so fixated on 2020  .... its no where near ready for flightdeck builders simple as that yet people moan trying to fit a square peg in round hole !!!   12 mths my thumb suck   if you have to have it then large lcd single desktop play unit....thats my 2 cents spent..lol
Quote from: RayS on August 29, 2020, 05:05:19 PMA cautionary tale: installing MSFS2020 on a system with FlyElise warping software.
Lovely....
I bought it on Steam, for that reason. Microsoft wanted strange things to be able to install it.  So got a refund, and went to the steam version. Still needed 1909 windows though, wasn't that bad.  but least your windows is up to date an your warping software LOL.
I think it's going to happen sooner than you think Bernard. They've announced an update within seven days that will fix the issue with Simconnect stealing frame rates.
Which means that Trevor will have it running his deck within a week.
That's just my 2 Cents.
So, what have I done for my simulator* today?
I decided to build a CNC router so that I could cut parts from MDF and acrylic. This is complementary to 3D printing, and probably, but not always, better than cutting things by hand.
I started making it about 2 years ago, but the project stalled. In the last few weeks I got back to it and got it working. It still needs a bit of tweaking, but it works. Attached is a picture of the machine, which has an almost 200x200mm work area, and a picture of a piece I cut with it. The cut piece is the front panel for the Davtron MB800 chronometer for a Beechcraft King Air.
The machine is driven by grbl running on an Arduino, so it can accept G-code directly. It uses a cheap rotary tool with 3.2mm (1/8") shank bits.
Generally my workflow is:
idea -> QCAD -> DXF2GCODE -> bCNC -> result
Not only is the software Free and Open Source, but the machine itself was based on a Free design called CNC v0.6 by Homofaciens.
https://www.homofaciens.de/technics-machines-cnc-v0-6_en.htm
* I'm not a simulator builder, I just like making things.
kattz
#984
Quote from: bernard S on August 30, 2020, 11:32:44 AMwhy is it mostly everybody is so fixated on 2020  .... its no where near ready for flightdeck
Possibly.
However, It installed perfectly on my 3-projector setup. Frame rates suck but I haven't tried it after the latest update.
The biggest factor I'm looking at now is that I'm anticipating 6 months to a year to totally convert from X-Plane to MSFS2020. My sim has 20 microcontrollers all tied to an X-Plane API through USB and they work quite nicely.
Moving to a new API architecture is a challenge and I don't want to get halfway through a conversion only to discover it could be done better with a different architecture.
Fire Panel continued
Testing Korrys retrofitted with LED bulbs.
Leds driven by FDS card. no resistors straight plug in
#987
Over the long weekend I did some initial testing on MSFS2020...
Overall I'm happy with the first release, considering there's still a lot of it not working.
What I hope they fix:
1. Way too much light bloom at night. On a 3 projector screen, this has the effect of everything being out of focus. It's a little nauseating. Note: You can turn this off but it has no effect. I hope they give us a bit more granular control over light bloom.
2. Rudder control is WAY overdone.
3. Controls are not smooth at all. Tried at different graphics settings but the result is that the plane tends to bounce around too much. Small corrections lead to big movements.
4. Visuals: There's no "Lateral Offset" setting. You can change viewpoints and pilot views but without the lateral offset you will crab endlessly close to the ground.
Granted, this is all magnified across 3 projectors, but compared to X-Plane, 2020 is way too jerky.
I'm not sure what the future of X-Plane looks like, but as I convert my sim over to 2020, I am making sure I can easily switch between sim platforms.
Hey Everyone,
Looks like some of you have been busy and with Fall on the horizon, I am sure we'll have more time to work on our sims.
Speaking of which, spent the whole day yesterday redoing my NTHUSIM settings (yep, still using version 3.0 because it works just fine). Decided to realign everything with a Johnson's self leveling Laser Level and what a huge difference it made. After doing all the vertical and horizontal alignment lines, I discovered that I never did the vertical lines very well before.
In other words, what I thought was vertical or plum before was not that at all. However, I can only summarize that it's due to my new screen configuration. I know that sounds funny since I am using the same screen, but how it's attached now is different and it helps me see things better, as weird as that sounds. Anyway, everything seems so much better...
Finally, did you see my post on USB Code 43 errors? Yeah, I just finished getting everything I mentioned above done and BAM! Code 43 errors on 2 PC's.  :o
Looks like my COM2 and GFC600 Autopilot shipped so I can finish my radio stack.
LORENZO
Greetings
Finally got the lights on and connected
with interface cards working
no seperate pc to run the gauges ( on order )
https://www.inside-tech.co.uk/fanless-quad-core-intel-mini-pc-dual-display#product-options-wrapper
I will let you know how it shapes up
no pc to run MS FS2020 yet
saving up for That bad boy
but having fun building
helloo
An accessory for the sim.  Water bottle and a coffee tumbler I made.  Less risk of a spill now lol.  20200919_210045_resized_1.jpg20200919_210157_resized.jpg
New Milestone with MSFS 2020.  Manual Engine Start is Fixed, and so are the Generators.  This is a MAJOR accomplishment.
A close friend had a bunch of inop  gauges from <Insert company name here> laying around so I put together a retro-fit kit designed to be driven by any micro-controller....
They turned out well!
Hey Guys,
There is so much nice working going on and I'm glad too see you're still posting here...thank you 😁
Regarding my sim, finally got a full flight in and on VATSIM. Only took 5 years...lol! Still got more to do with rebuilding yet, like install the new start switches, steering tiller, compass and more...
Also, I've gotten back to my CNC machine and started doing more with it. Eventually, going to try and make some parts for myself, but it might be another 5 years...ROTFLOL!
Trooping
Hey Guys,
The CRJ sim has come along since my last post.  I would say around 80% finished.  Radios remain a bit of problem as there is no 2D popout of the RTU, but I can still tune through the FMS.  Lots of little tweaks etc to do, but its flyable now.  Version 2.0 is going to be a complete rework of the LED lights on my fake "korrys" using mobiflight, but for now just going to enjoy flying for a bit.
Superb cockpit but why do you use the cockpit view and not just the plain outside view ?
Trooping
Hi Jack,  I do use the outside view, I was just changing settings in the pics
kattz
#998
Today... I paid for the FDS shell and interior kit, fire panels, O2 panels, all of the radios/comms/radar, and some items for the NG-ADV that I was missing. Oh, and $890 for shipping.
It's official.  I'm too broke now to pay attention.
#999
Been doing some flying instead of building...
Just a short departure out of Vegas, and a 180 to fly back down the strip before heading home.
