October 20, 2026, 08:52:01 PM
448 Guests, 0 Users
  • Online today: 797
Guests: 448
Total: 448
Started by helloo, June 18, 2019, 01:03:04 PM
helloo
I have some Dzus fasteners that I need to install but it appears that something (tool?) is needed to do this.  I am installing blank plates in areas where I do not have anything and need to get these Dzus into the plates.
Just drill the plates so that the bottom part of the Dzuz gets in and tighten 1/4 turn.
The only difference with properly seated Dzus is that they are not attached to the plate when you unfastened them, but the end result is the same.  :D
PS: if you use real blancs without Dzus installed just enlarge the hole so that...
ifeliciano
You need a specific sized hole ans a special flaring tool to "crimp" the fastener to the sheet metal. Look at the PDF linked here. Bottom right of first page.
https://www.southco.com/static/Literature/D5.en.pdf
peterkwu
Search "Dzus fastener tool" on eBay to find what you're looking for at reasonable cost
Check on my progress at
http://www.fly737ng.com
In my humble opinion, no need to spend a penny on that for a few plates.
Actually, if your plates have no holes, the challenge is the precision of the hole drilling so that it fits the rail ( the tolerance is really thin) . The fact that the dzus is not crimped to the plate is non important. The dzus fastener will just do its job when you tighten it as it garbs the rail wire and keeps the plate fastened.
helloo
Quote from: ifeliciano on June 19, 2019, 04:15:21 PM
Sounds like a plan.  Thanks.
If you are handy with a lathe you can quickly whip up a pair of tools to use in a hand press, or even a hammer.
I did 2 full overheads with these 2.
Buster99
Hi Mick,
That is exactly what I did, it took a few tries but works quite nicely.
Marc
