June 16, 2024, 11:20:16 AM
134 Guests, 0 Users
  • Online today: 175
Guests: 134
Total: 134
Morning in New Zealand. Sorry, I have a very busy day. I will get onto it as soon as I can. Probably something very simple. Sorry.
Working on it. Confirmed it doesn't behave as expected when I simulate the code. Probably a thinko (it's like a typo, but it happens when you're thinking).
_alioth_
I can not test now, but it could be related to definitions inside the Case:
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
I remember I have had problems with this in the past.
Try global definitions. Just in case.
_alioth_
I have tested in tinkercad simulator (no arduino here now) and it says some error related to definitions inside the case.
I have tested this code and seems to work as it should (but tinkercad is not the same as arduino so... ). I have added some Serial.prints inside the case just to test:
Quote/*
    For use with "Link2fs_Multi"
String flaps;
String fuel;    // Re-use this variable for all fuel gauges as we only do one at a time
// PWM pins for gauges. Must be one of 3, 5, 6, 9, 10, or 11 for Arduino Uno
// Flaps
int flaps_PWM_out_pin = 3;
// Fuel
int fuel_L_PWM_out_pin = 5; // Left fuel gauge
int fuel_C_PWM_out_pin = 6; // Centre fuel gauge
int fuel_R_PWM_out_pin = 9; // Right fuel gauge
// Variables for fuel gauges
// Can be reused for each gauge as we do one at a time.
int fuel_PWM_out;
float fuel_percent;
float fuel_lbs;
float flaps_degrees = 0;
int PWM_out = 0;
unsigned long previousMillis;
// Variables for flaps gauge
const int flaps_max_PWM_per_slot = 1; // Maximum amount we can move in 0.1s
void setup()
  Serial.begin(115200);
  // Set up PWM pins.
  pinMode(fuel_L_PWM_out_pin, OUTPUT);
  pinMode(fuel_C_PWM_out_pin, OUTPUT);
  pinMode(fuel_R_PWM_out_pin, OUTPUT);
  // Set PWM values to zero.
  analogWrite(fuel_L_PWM_out_pin, 0);
  analogWrite(fuel_C_PWM_out_pin, 0);
  analogWrite(fuel_R_PWM_out_pin, 0);
  flaps_PWM_target = 0;
  flaps_PWM_current = 0;
  first_flaps_PWM_value = true;
void loop() {
  if (Serial.available()) {
    CodeIn = getChar();
    if (CodeIn == '=') {
      EQUALS(); // The first identifier is "="
    if (CodeIn == '<') {
      LESSTHAN(); // The first identifier is "<"
    if (CodeIn == '?') {
      QUESTION(); // The first identifier is "?"
    if (CodeIn == '/') {
      SLASH(); // The first identifier is "/" (Annunciators)
  // Other tasks
  // Currently we have to smooth the flaps output.
  // Fuel gauges don't need smoothing.
    // We're on a 100ms boundary
    previousMillis = currentMillis;  // update the time we were here
      if (flaps_PWM_current > flaps_PWM_target) flaps_PWM_current = flaps_PWM_target;
      if (flaps_PWM_current < flaps_PWM_target) flaps_PWM_current = flaps_PWM_target;
    else {
  while (Serial.available() == 0); // wait for data
  return ((char)Serial.read()); // Thanks Doug
void EQUALS() {    // The first identifier was "="
  switch (CodeIn) { // Now lets find what to do with it
      //Do something
      break;
    case 'B':
      //Do something
      break;
    case 'C':
      //Do something
      break;
void LESSTHAN() {  // The first identifier was "<"
      //Do something
      break;
    case 'B':
      //Do something
      break;
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
      PWM_out = flaps_degrees * 7.727;
      if (PWM_out > 255) PWM_out = 255;
      flaps_PWM_target = PWM_out;
      if (first_flaps_PWM_value) {
        first_flaps_PWM_value = false;
      Serial.print("G");
      Serial.println (PWM_out);
      break;
    case 'X': // "X" left fuel gauge
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      // It's a percentage of full, where full is 9200 lbs (left)
      // Expected range is 000 to 100
      fuel_percent = fuel.toFloat();
      fuel_lbs = fuel_percent * 9200;
      // Convert lbs to PWM 0-255.
      // 0 lbs on gauge is PWM 75
      // 10,000 lbs on gauge is 255
      // So PWM is (1.8 x (lbs/100)) + 75
      fuel_PWM_out = ((fuel_lbs * 1.8) / 10000) + 75.0;
      if (fuel_PWM_out > 255) fuel_PWM_out = 255;
      // Drive the gauge
      analogWrite(fuel_L_PWM_out_pin, fuel_PWM_out);
      Serial.print("X");
      Serial.println (fuel_lbs);
      break;
    case 'Y': // "Y" centre fuel gauge
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      // It's a percentage of full, where full is 4400 lbs (centre)
      fuel_lbs = fuel_percent * 4400;
      // Drive the gauge
      analogWrite(fuel_C_PWM_out_pin, fuel_PWM_out);
      Serial.print("Y");
      Serial.println (fuel_PWM_out);
      break;
    case 'Z': // "Z" right fuel gauge
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      // Drive the gauge
      analogWrite(fuel_R_PWM_out_pin, fuel_PWM_out);
      Serial.print("Z");
      break;
void QUESTION() {  // The first identifier was "?"
      //Do something
      break;
    case 'B':
      //Do something
      break;
    case 'C':
      //Do something
      break;
void SLASH() {  // The first identifier was "/" (Annunciator)
  //Do something
Well, how about that?
I concur. I put a bunch of print statements in, to see what was happening: nothing.
Then I moved the variable definitions out: success!
This is why we test code before we post it to the internet.  :-[
Thanks Arturo.
And here's why:
https://stackoverflow.com/questions/92396/why-cant-variables-be-declared-in-a-switch-statement
I've been doing this a while and I've never written anything that happened to cause that problem. I'll try not to do it again (I prefer making new mistakes).
_alioth_
new mistakes are always funnier, Ame!  :)
I would like to code some cleaner and efficient way to read the link2fs data.
But I would need to know if:
- ticking the box "include CR/LF" there is always a return at the end of each command.
- ticking the box "include comma's between" sends always a "," at the end of each command.
First one, then the other. Not both at the same time, if posible.
Can you help me with this Mach7?  you can see it in link2fs "to card" window or put some screenshots.
Hello guys, the program works perfectly!!
Thank you!!!!!!!!!!..
@Arturo...I thought I knew what you were talking about with respect to the fuel quantity indication and battery bus power...now seeing it it makes perfect sense to me what you were trying to tell me. Still not an issue for me in this application, but now I understand what you were saying..thanks.
I will put up some screen shots up today.
Also...and not a really big deal...but is there anyway to have the fuel needle(s) move a bit slower to there requested positions?
I notice that it may be beneficial, (to the instrument life itself) to have the needle move slowly to the requested fuel levels...that is to say in transient states the needle will move very fast, epecially when it returns to zero from a high fuel state..the needle "bounces" off its stops.
This may not be too big of an issue...just thinking that anything that moves a bit slower may increase the life of the instrument itself.
Quote from: _alioth_ on August 24, 2023, 02:18:50 AMnew mistakes are always funnier, Ame!  :)
I see where you're coming from, but nobody uses link2fs anymore, and the website is dead. Link2fs is based on FSConnect, from here:
https://www.dirks-software.ca/
One day FSConnect.dll will die too. However, I thought about using Python to access FSConnect.dll directly, then put a Python wrapper around it. Then it would be no longer necessary to use link2fs.
Furthermore, all the processing could be done in Python, thus leaving the Arduino to output a PWM value to a pin only.
Quote from: Mach7 on August 24, 2023, 02:39:41 AMHello guys, the program works perfectly!!
Excellent. Glad it's working. Sorry about the rookie mistake.
Regarding damping the needles, a very common technique is to filter the target position with a simple running average:
new_position = (current_ position+target_position)/2
I'll code something up later (now it's bedtime in New Zealand), but that's what I'd do.
Thanks again ame
And many thanks to both of you guys!!
Once I have it all connected up I will post a video!
Jason L
Any thoughts of using mobiflight as your interface instead of link2fs?  Actively supported with multiple flavors of arduinos and works really well.
Quote from: Jason L on August 24, 2023, 01:15:52 PMAny thoughts of using mobiflight as your interface instead of link2fs?  Actively supported with multiple flavors of arduinos and works really well.
Does it support FS9?
Since it's all working now there's probably not much sense in reimplementing it.
Hello guys, as promised a short video and a pic of the Arduino board setup...i still have to clean some wires up and situate the board...but for testing it is good for now.
Thanks again ame and Arturo for all the help.
It's nice to get away from those clunky OpenCockpit controlled dc servo motors..
As far as Mobiflight is concered...I looked into that, but as far as I can see there is no support for FS9.
https://www.youtube.com/watch?v=khojFlD_xV4
Next step is the flaps input, right?
Only half-kidding. You said it was a linear pot hooked up to the flaps lever. Arduino has an analogue to digital converter (ADC) so can detect the position of the pot. Link2fs allows you to send commands back in to the simulator.
Would need to prototype it entirely before removing the current system you have which works, but I think it should be possible.
Ok. I've improved the filtering on the flaps, so it should be less jerky. I've also added some smoothing to the fuel gauge so they don't jump at startup, but general movement won't be affected because the fuel gauges move so slowly.
Take a copy of the working code that you are happy with in case this code doesn't work, then you can go back to it if you need to. I did test it this time, but that is no guarantee...
Quote/*
String flaps;
// Flaps
// Fuel
int fuel_L_PWM_out;
int fuel_C_PWM_out;
int fuel_R_PWM_out;
int fuel_PWM_out;
// Record last needle position for damping
int last_fuel_L_PWM_out;
int last_fuel_C_PWM_out;
int last_fuel_R_PWM_out;
float fuel_percent;
float fuel_lbs;
float flaps_degrees;
float filtered_flaps_degrees;
int flaps_PWM_out;
// The gauge on the simulator travels from 0 to 33 degrees in about 35 seconds
// We should introduce fractional degrees for the physical gauge so that it
// moves smoothly between integer degree positions.
const float flaps_max_degrees_per_period=0.0943; // Maximum amount we can move in 0.1s
bool first_flaps_value; // Flag to see if we should go directly to target
void setup()
  // Set up PWM pins.
  first_flaps_value=true;
  last_fuel_L_PWM_out=0;
  last_fuel_C_PWM_out=0;
  last_fuel_R_PWM_out=0;
void loop() {
    CodeIn = getChar();
  // Other tasks
  // Smooth the needle output.
  // For flaps, we calculate intermediate flaps positions and then move the needle.
  // For fuel, we calculate the PWM output, and apply a running average filter.
    // flaps_degrees is updated elsewhere when new data arrives.
    // Filter the gauge needle position slowly over time.
    if (flaps_degrees > filtered_flaps_degrees) {
      filtered_flaps_degrees += flaps_max_degrees_per_period;
      if (filtered_flaps_degrees > flaps_degrees) filtered_flaps_degrees=flaps_degrees;
    else if (flaps_degrees < filtered_flaps_degrees) {
      filtered_flaps_degrees -= flaps_max_degrees_per_period;
      if (filtered_flaps_degrees < flaps_degrees) filtered_flaps_degrees=flaps_degrees;
    else {
    if (first_flaps_value) {
      first_flaps_value=false;
    flaps_PWM_out = filtered_flaps_degrees*7.727;
    analogWrite(flaps_PWM_out_pin, flaps_PWM_out);
    // Now update the fuel gauges. Just a simple digital filter.
    // Yes, this should be done as an array...
    fuel_PWM_out = ((3.0*last_fuel_L_PWM_out) + fuel_L_PWM_out)/4.0;
    last_fuel_L_PWM_out = fuel_PWM_out;
    // Lighter filter on centre gauge
    fuel_PWM_out = ((2.0*last_fuel_C_PWM_out) + fuel_C_PWM_out)/3.0;
    last_fuel_C_PWM_out = fuel_PWM_out;
    fuel_PWM_out = ((3.0*last_fuel_R_PWM_out) + fuel_R_PWM_out)/4.0;
    last_fuel_R_PWM_out = fuel_PWM_out;
       //Do something
    break;
    case 'B':
       //Do something
    break;
    case 'C':
       //Do something
    break;
       //Do something
    break;
    case 'B':
       //Do something
    break;
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
      // Moving the needle will be done in the main loop.
    break;
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      fuel_L_PWM_out = ((fuel_lbs * 1.8)/10000.0)+75.0;
      if(fuel_L_PWM_out > 255) fuel_L_PWM_out=255;
    break;
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      fuel_C_PWM_out = ((fuel_lbs * 1.8)/10000.0)+75.0;
      if(fuel_C_PWM_out > 255) fuel_C_PWM_out=255;
    break;
      fuel = "";
      fuel += getChar();
      fuel += getChar();
      fuel += getChar();
      fuel_R_PWM_out = ((fuel_lbs * 1.8)/10000.0)+75.0;
      if(fuel_R_PWM_out > 255) fuel_R_PWM_out=255;
    break;
       //Do something
    break;
    case 'B':
       //Do something
    break;
    case 'C':
       //Do something
    break;
  //Do something
Incidentally, I am testing with this:
https://wokwi.com/
You can simulate the Arduino, which means you can compile code and edit it in the browser, and you can simulate serial input and output for testing.
Saves having something hooked up on the bench.
Thanks for the updated code ame!
I will upload it when I get back from work..i will be on the road for 4 days starting tomorrow, so will be able to update you on Monday.
Again...I really appreciate your time, knowledge and commitment.
Thank you!!
On a related note, how can we encourage more people to build things? This is "cockpitbuilders.com" after all. Or is everyone on the mobiflight site these days?
I have enjoyed this little foray into link2fs, and in some ways I'm disappointed that it's gone. MSFS now has "Simconnect", which can be utilised in a number of ways, but that's no good for FS9.
_alioth_
Quote from: ame on August 24, 2023, 08:09:54 PM
Yes... and I the freedom you have using custom arduino code is unlimited. The only limit is your imagination.
You can not interface real complex things with mobiflight.
I really like the arduino/teensy code size. My problem was always the comunication with p3d.
Xplane is great with teensy, because teensy has native support to share variables with xplane:
https://www.pjrc.com/teensy/td_flightsim.html
I would rellay like to have something similar in p3d/msfs.
I know simconnect, but I never find the strength, and I don't even know if I would have the skills to program c++ plugins to  do the communication with arduino.
So, I am using lua scripts with FSUIPC.
The Lua script in fsuipc talks with simconnect. So you read variables and send values to arduino and the reverse.
The advantage over link2fs is you can control poll rate, read Lvars, and take control over variables.
For example, level gauge has only 100 steps in link2fs, but with the script I can read the lbs and send from 0 to 1000, or the lbs, or whatever I want.
But I would like to have something more "comercial grade", a plugin, dll, exe... not editable por third parties.
Arturo.
Jason L
Will try not to read too much into your comment but the assumption that if you use MobiFlight you aren't building a cockpit seems a bit of a stretch.  It is by no means plug and play.  One could ask the same of Prosim then too, one should be just building everything from scratch?  I've got a combination of OEM and vendor-built parts in my 737, fully interfaced OEM ACP's using MobiFlight with FSUIPC and Prosim.  Written scripts in SIOC for some of my OpenCockpits stuff.  You can make your own firmware for MobiFlight to support more advanced features of the arduino.  It's all open source and there is a large community to help support your endeavors.  To me, that is cockpit building.
I like this site and the historical information that it provides, but it isn't a significantly active source for new information anymore.  Many have turned to places like, yes, as you mentioned MobiFlight's discord server, Prosim's forums, whatsapp groups etc.
Off my soap box now.
Jason L
You can get the registered copy of FSUIPC for FS9 for free now, with that, yes mobiflight will work.  You can use it strictly with FSUIPC offsets then.
Quote from: ame on August 24, 2023, 01:26:08 PM
Quote from: Jason L on August 25, 2023, 05:49:10 AMWill try not to read too much into your comment but the assumption that if you use MobiFlight you aren't building a cockpit seems a bit of a stretch.
Ah, sorry, that was not my intention at all. I meant "where are all the cockpit builders?". We've been helping Mach7 here, but there are no other similar threads (building something) on this site. So, where else are people doing it and writing about it?
Hello guys...back from work and will try the new code out and get back to you!!!!
