May 16, 2024, 02:57:11 PM
714 Guests, 0 Users
Guests: 714
Total: 714
B767 MIP
Started by Goodenough, January 05, 2018, 03:57:34 PM
Goodenough
Here are some pics of another project I'm working on. I worked on getting some instruments painted for my B767 MIP. I got these on EBay for cheap and modified them to make them look like the real ones. It took some time with automotive paint and mixing together other paints to achieve a Boeing match. Still need to get the glass face put back in maybe do that this weekend.
Looks Good Perry, that's one heck of a project.
Sweeeet! Keep the pictures comin! This is awesome!
Goodenough
Thanks.... I will work on getting more of the MIP populated when more instruments become available. My biggest problem is getting ahead of myself and not taking it slow. I have approx. 80% of the overhead instruments and 50% of the pedestal. Some of the higher price items like airspeed and stand by attitude indicator will have to wait until price comes down which may be awhile. I want to see if a LED strip can fit inside the instruments that you see in the MIP so they light up and if not then under the glare
Quote from: Goodenough on January 06, 2018, 04:02:36 AM
Those instruments should have internal lighting usually 5V...??
Goodenough
Jack...I modified the RMI and replaced a few things like the broken glass, updated the frame, removed a few things  like the internal lights from this unit. Here is a picture of it....is it possible to reinstall and have it work?
I actually replaced my instrument bulbs with led's. Just find the size you need. I interfaced them with my FS Nav light fsuipc offset. So when the Nav lights go on, so do my instrument lights.
Goodenough
Trevor that sounds interesting...I will check it out. I figure its easier to stick with something that I know how to do. Here I bought the LEDS off Amazon and connected it to a power source.  Just need help with knowing what the best way is to connect multiple LEDS to one power source and interfacing it with a program like you have. I got the RMI lit....now I need the i struments in the MIP lit.
Not sure about the leds.
The best is to keep it as is ( do not remove lighting) with the 5V bulbs.
I have some real gauges on my MIP and OVH, all with internal OEM lighting.
Just use a relay card and interface it as Trev suggested.
Below are two pictures with the devices I use. Same idea as what is in your gauges. Mine just goes on the outside of the gauge.
My interface cards can drive 2 leds on each output. So I just put them in parallel.
The led strips you have are designed for 12V. That will be tricky on your interface.
Jack is right though if your not interfacing your lights and just connecting them to a 5v Switch. His idea is better.
Goodenough
OK thanks both of you for your help. I will look at my other three gauges, the clock, altimeter and airspeed and see if I can get the internal lights to work. Is it just a matter of seeing which pin at the back controls the lights.?
As you notice, I'm somewhat technologically challenged
I found the clock on e-bay and the price was a little over $400.00 USD with shipping.   A fair price, in my opinion, for a B747 style clock going into a B767
Goodenough
#11
Here is what it looks like in the panel.
737NGer
Looking good!
This is what I like to see...when OEM projects make progress lol!  ;D
Goodenough
#13
Thanks I have been working on getting the Glare shield out and removing parts from it, now onto sanding all the scratches , and preping for paint. I also got my knobs for the RMI which Im happy to get from Shapeway.
Man i am so jellous of that real cockpit...
If i was to start again i would go for like a real dc-9 or a md-80 or a 757/767.
The 757 is really a great choice, not as expensive parts as the 737 but in my oppinion just as awesome aircraft.
Goodenough
Thanks. I want to create a dummy stand for the MIP to work on wiring and screen setup. I'm going to do a cad drawing of the MIP and pedestal stand.  Its too cold to work out there now where the cockpit is. The temperature today is -10 and the wind makes it feel like -19. Too coldddd...
Haha i also work in a storage that have bad heat in the winter. :)
Right now i am sanding and painting the walls but i know how it feels to play with the simulator in +2 degrees! Hehe
Goodenough
#18
Thanks. I may just get me one of those to warm up the place. It doesn't help when you're working on removing a part and can't see because you only see your breath. I'm glad to see others are also working in same conditions. This picture was taken  on a warm sunny 23 degree day.
Quote from: jackpilot on February 03, 2018, 05:02:24 AM
Way to go...these little devils are super efficient.
https://www.bmr.co/en/chaufferette-portative-040-1333.html
:P
I tried one of those in my garage...  4000Watt, until I got my first $500.00 Hydro bill for the month LOL
They have to be hooked up to 240V !
Goodenough
#22
I may have to wait till Spring....when it warms up until then I'm going inside where its warm.
Goodenough
I just found another addition to my MIP panel....a stand by horizon indicator. Eventually will understand how to connect it to a power supply to get it to light up.
