June 03, 2024, 03:12:15 PM
151 Guests, 0 Users
  • Online today: 166
Guests: 151
Total: 151
Real 737 TQ conversion (updated 11/13)
Started by 727737Nut, September 20, 2011, 03:28:16 PM
Quote from: ekznamu on October 04, 2011, 09:56:55 PM
Rob,
nice work, where did you get the clutches ? I'm looking for them a long time.
Uwe
Ployclutch.com then use the link to find a dealer nearest to you.  Also there are a few mail order places that have them but they were actually higher priced.
Not to hijack Rob's post Check my new post on Polyclutch.
ekznamu
#27
Thank you both, an excellent source for that stuff.
It's not easy to appreciate the force needed to transmit the power.
Rob, what kind of clutch did you use for the lever driver motors ?
Would be SAS20 a good choice ?
Uwe
Hello,
I used the SAO20-8mm   I think it is important to have the adjustable one to compensate for different variables in the installation.  The SAS20 would probably work but again it depends on how your lever system is built.
dnoize
Quote from: 727737Nut on October 04, 2011, 11:55:46 AMStef,
Yes, that is correct. It uses the original chain sprocket which is #35 chain here in the USA.  The motor sprocket can be from 10t to 15t depending on RPM of motor being used. I used a small gearhead motor due to space but a larger remote mounted motor could be used also.
Thanks a million !!
Time to source a # 35 chain in the US then !
Thanks again
Stef
Just a quick update, had to order new motors as the ones i had did not work good enough for my standards.  I did get the rest of the light plates cleaned and tested and completed the painting.  Motors should arrive tomorrow so more progress soon.
Well I finally got the new motors installed for the throttle levers.  Turned out really good with the chain to cable hardware I used.  With 5vdc applied to motors, the levers move nice and smooth!!
Next up is the string pot install and then the spoiler lever drive and trim indicator drive. The 3rd pic is of the trim indicators and upper side panels.  Compare to original pic above in 1st post.  Just a slight improvement. :)
[smg id=185]
[smg id=186]
[smg id=187]
Bloody unreal Rob!
Where the f--k did you get the trim indicators panels?
I have one nice one and one crappy one on my -300 TQ
Thanks guys!  Nat, those are far from perfect.  ;)  I just touch of the edges and clean them really well.
I got the String pot's installed on the levers. Working on Flaps now.  Post more pic's later today.
hexpope
Hey Rob,
Your doing a fantastic job. I'm really looking forward to seeing the finished product and up and running. You will post a video of it when it's finished ?
OK, Got the string pot's installed.  As usual, they were easy to install and work flawlessly! :)  The flaps pot turned out really nice. I may redo my own now. lol   As always, I have more pics if anyone needs them for reference.  The cable I use is 1/16" 7x7 wire rope.  I install a lead ball (aka sinker) around cable and drive/wedge into original location on lever wheels. Then route cables around pullys to the motor/clutches.  Simple and tough.
[smg id=188]
[smg id=189]
Here a couple of pics of the TQ reassembled.  I think it looks pretty good compared to the original photo of the TQ when i got it.  Hope Nick is pleased.  Lots of man hours getting it to this stage. I have a few touch-ups to do and finish wiring and spoiler servo install.  Getting closer now. :)
[smg id=190]
[smg id=191]
I just wanted to add that although it looks like new, that is exactly what I didn't want. In person it looks like a used but in good shape, 737 throttle. I don't want a so new it looks like a toy thing. lol  It maintains it's personality that way.  Just like in a real plane where things are touched up by hand if at all.
Rob,
Your work is absolutely incredible!   Cant wait to get mine over to you!
hexpope
Either way Rob, your work on that TQ is great. As I said before I can't wait to see it in action working like the real thing. Totally profesional job. Fair play !
Rob, I can't say enough to  praise, and it's only looking at the pictures now!  :rock:  :rock:  :rock:
I bet when I get it it will look even better. Exquisite work!
Thanks a million,
Alexandrite
This is looking so fantastic :)
Couldn't believe the dirt in there in the very beginning!
fsedano
Your job looks fantastic!!! I'm going thru the same process, and I'm just stuck on how to remove the trim wheels. Can you post some pics / tips?
Also, I'm located in Switzerland, and I find difficult to find required mecanical pieces (motors, chain sprockets...) Would you have some pointers on where did you buy them? Maybe I can order online. I saw another colleague here on the forum from NL, maybe we could even order a batch of pieces and share costs.
Thanks!!!
(btw, my project page, sightly outdated: www.fransedano.net)
Quote from: 727737Nut on September 20, 2011, 03:28:16 PM
Follow along as I convert a customers real 737 throttle quadrant for use in his flight simulator.  It will be fully motorized and offer the durability of REAL internal Boeing parts and select aftermarket parts to make it fully compatible with FSX.
Hi all,
A couple more pictures, got the servo's installed for the Spoiler Arm and Trim indicator.  Any questions feel free to ask.
[smg id=226]
[smg id=227]
Efe
Quote from: fsedano on October 28, 2011, 07:52:24 AM
Thanks!!!
[/quote
You can try Farnell.ch, that was where I got all my cockpit building parts when I was living in Switzerland.
__________________
Efe
fsedano
Hi guys,
Trying also to convert a real 737 TQ, but stuck dismantling it. It seems it's not exactly same version as on these pics.
I'm stuck with removing central axis, the big nuts just rotate but they don't come off. Any ideas?
This is current state:
http://www.fransedano.net/?p=297
Any help is welcome ;-)
Did you try holding one while turning the other?
fsedano
Yep - They are independent on each other. See
http://www.fransedano.net/?p=312
It's not one long axis, but two halves. As far as I see, for even changing the throttle cable everything must be dismantled? Can't be so difficult...
Did you try holding the inner tube while turning the outer nut? It looks like there 2 slots to keep the inner tube from turning while rotating the large outer nut.  That tube is full width, trust me.
