June 03, 2024, 04:00:54 PM
167 Guests, 1 User
  • Online today: 166
Guests: 167
Total: 168
help needed 7x 27" wideview setup and th2go
Started by cestlavie2010, July 22, 2012, 07:32:28 AM
cestlavie2010
ok....try to be short :-)
Currently i have 3 pc's with wideview:
MAIN PC:3x 27" th2go   frontview: setup is like MIP so middle one centered and L little angle and little angle. (together one display in Windows!)
LEFT PC: 2x 27" th2go left view
RIGHT PC:  2x 27" th2go right view
I am struggling with best possible view:
currently I have just 90 degrees left and 90 degrees right on both pc's.
a) zoomfactor only 1 of 1.5 possible in that range...cannot go in between.
b) see on frontview part of left and right view (on al pc's windows only has one display because of th2go!)
c) distortion because of "crabbing"  effect ?
My problem is: I dont know where to start to correct these problems...  Especially crabbing effect maybe a generic FSX problem. But first I like to fix the problem a) and b)
Hopefully someone can point me in correct direction how to set this up most efficiently.
Off course I already tried some thing but not satisfactory
My front view is: 5760 x 1080 and side view: 3840 x 1080
Thanks a lot!
Remco
Jon Boe
I think that all three images (Left, Center, and Right) need to be the same size.  If you are using two screens on left and right you have to use two screens on the center as well.
Regarding the crabbing, have you changed the eyepoint in the aircraft.cfg file to 0.0?  There are three numbers in that section.  Change the center number (typically a negative number) to 0.0 on all three computers.
Jon
