June 04, 2024, 03:49:21 AM
125 Guests, 0 Users
  • Online today: 150
Guests: 125
Total: 125
1/4 turn fasteners for OEM overhead
Started by Ethanoost, February 22, 2017, 04:43:08 PM
Ethanoost
Hi everyone.
I'm planning to install a real 737 overhead frame into a FDS shell. I'm looking for ideas to make use of the 1/4 turn fasteners already in the overhead frame. I have the overhead install kit from fds but they don't use 1/4 turn fasteners but just screws. I will need the corresponding receiving connector. I notice they can be bought of eBay or hardware sites. But there are so many types and sizes...
Has anybody done this before? Any tips will be appreciated.
Ethan
Sent from my SM-G930F using Tapatalk
Those are called Dzus fasteners.  When you order your overhead panels from FDS just tell them you are using a real overhead frame and would like your panels to have Dzus fasteners installed.  They will charge extra (and not cheap) but well worth it.
Easy
Ethanoost
Thanks but what I referring to is the fasteners that connects the frame to the shell. As seen in the pictures.
Oh, I see.  Yes, those are camlocs and you need the appropriate sized camlock receptacle.   I have a real overhead panel and the FDS shell.   I bought a set of camloc receptacles for mine from Aircraft Spruce.  They worked like a charm.
https://www.aircraftspruce.com/categories/aircraft_parts/ap/menus/ha/fast_1camloc.html
Quote from: Ethanoost on February 22, 2017, 04:43:08 PM
.... I have the overhead install kit from fds but they don't use 1/4 turn fasteners but just screws.
I have FDS shell /overhead and it all came with those fasteners male/female. not screws
Ethanoost
Thanks guys.
I asked Steve at FDS and he said they discontinued using the real fasteners. Not sure why. Maybe price... thank you for the info.
Ethanoost
Scott, you don't perhaps remember which size camloc you bought?
Aircraft Spruce Part # 04-03475
C-SPEC MS212-12N 2600 | 2700 RECEPTACLES
Ethanoost
Thank you very much.
Ethanoost
Quote from: XOrionFE on February 24, 2017, 07:56:05 AM
Hi Scott
I ordered the parts as you described above. But they are too small. Are you sure that is the correct part number. There are others on their website. Maybe you sent me the wrong numbers.
Thanks. Ethan
Well I originally ordered two different sizes and one size was too small and the other was correct.   I thought I had given you the correct one but apparently not.   I apologize.   These are the 2 types I ordered.
C-SPEC MS212-12N 2600/2700 RECPTACLE
214-16N CAMLOC 4002 RECEPT # 214-16N
So I guess it must have been the second  one  :-[
Ethanoost
Quote from: XOrionFE on March 15, 2017, 07:21:23 AM
