May 22, 2024, 10:25:01 PM
45 Guests, 0 Users
  • Online today: 728
Guests: 45
Total: 45
Started by helloo, July 11, 2019, 08:21:26 AM
helloo
Where to find or how to make this switch guard for the Stab cutoff?
FDS may have it.
They are called T-Lockers
As usual Boeing has a knack for ugly and antiquated hardware.
The solution below has more appeal IMHO
helloo
In the photo above is that just a standard switch guard?
These are made by MSP Aviation.  Part number is 019803-001
You can purchase direct from MSP or here: https://wbpartsexpress.com/019803-001    (Be warned - OEM Prices apply ;)  $107 each.)
Quote from: helloo on July 11, 2019, 01:53:10 PM
Yes, and so much better than the ugly T-scrap
It is your airplane and there is no enticement to use outdated parts to avoid cost of new certification... :P
3D print job there! Need an Modeler Person to make it and I could print it...
@ Mick
Thanks for the link.
Amazing selection of hardware
Some very expensive some not.
Check connectors for instance
Great
I've already modelled these for my own TQ, see attached. Fairly simple design and easy to print, just two parts and a 2mm steel rod for the hinge pin.
I run a 2mm drill through one side and tap the rod into the other side. You need to make sure the hole in the moving part is clear.
I imagine the real ones have a spring to hold the flap in position, it could be done but I didn't bother. If you don't have a printer there are a number of companies on Thingyverse who will print it for very little money... in the UK about £3 each... or $4.00 (STL file Attached)
Alternately you could get a couple of these flick type switches on ebay, which I fitted to my original TQ,
[ebay]361793111625[/ebay] They're not exactly the same as the originals, it depends how fussy you are.
Hope that helps.
There you go Mike, Joe comes to the rescue... :D Way to go Joe!
If you can, find someone local to print them or do as Joe suggests, very inexpensive that way.  :idiot:
