June 04, 2024, 06:09:24 AM
94 Guests, 0 Users
  • Online today: 150
Guests: 94
Total: 94
Build new driver for PFC Cirrus flight console possible?
Started by allergiecheck, October 02, 2019, 05:01:19 AM
allergiecheck
I own a Cirrus PFC flight control from Precision Flight control, which works fine, but I would need different switch commands in X-Plane 11. Since it is a Windows HID Device: Do you think it is possible to write a custom driver for the console without support from the manufacturer? I have programming skills in C#, but never programmed any drivers before...
Thanks, Thomas
If I were you, I will pull the interface out, and install an arduino, and re-interface it to x-plane datarefs..  no need to reinvent the wheel.
If it's a true HID device, it should be treated as a normal joystick?
To Trevor's comment, if you plan on using it with X-Plane and don't plan on going back, then gutting it is your best option.
You could interface it to a Teensy 3.2, which opens up all sorts of capabilities. You'll just need the TeensyDuino plugin from PJRC.
In fact, once programmed it will function as a typical joystick device regardless of the sim, no matter if you use PJRC or not.
