May 08, 2024, 12:55:28 PM
555 Guests, 0 Users
  • Total Topics: 7,853
  • Online today: 562
  • Online ever: 831
  • (May 03, 2024, 12:39:25 PM)
Guests: 555
Total: 555
COUNTDOWN TO WF2022
Primary 6 Desktop Flight Simulator
Started by RojanTrojan, August 27, 2010, 11:30:00 PM
RojanTrojan
I thought I would move myself out of the "New here? Introduce yourself" section. I'm building a generic flight simulator based on a C172 that targets the 6 primary instruments as well as ignition, lighting and a Saitek radio. I've now assembled the case built out of MDF and threaded rod. This is the bare skeleton that will hold my acrylic panels. Next stage will be to coat it in primer and paint it white. It will then be draped with sheet aluminium, which will be also painted white.
Rhydian
Very nice work. Yes you no longer need to be new here........
Looks great.   Can see you really pay attention to detail.   That should turn into one nice GA pit.   I look forward to seeing your progress.  Keep the pictures coming!
Which software do you use?
I built a trainer for a Flightschool a good while ago and used the Project Magenta black GA .
Superb graphics , super smooth instruments and easy to place and size. Way less expensive than the glass cockpits. A two computers network doing all the work vey smoothly.
just for info.
JP
RojanTrojan
Quote from: jackpilot on August 28, 2010, 05:22:15 AM
just for info.
JP
Hi Jack,
I use simkits instruments for the left hand side so it would be their TRC software that runs all the instruments. I must admit they aren't the smoothest on the planet, but beautifully built and blimey they are very expensive to buy! I have seen a video of GA build (Steve1970 on Mycockpit.org) using a screen for the instruments, which I am guessing is the PMGA software. I envy how smooth they run.
I am in the process of designing another project after this one finishes. (I can't get enough of pit building). I am doing a mini rendition of a Diamond DA-40 with Project Magenta's GAGC software.  I have to say It works out much cheaper than using Simkits' instruments.
Rhydian
Flightillusion instrument do not use servos and are smoother but when the graphics are good (PM or REalityXP) a full screen of them is cheaper, easier and finally as realistic.
RojanTrojan
I'm starting to cover the case in 1.2mm sheet aluminium. Once the pieces have been "bolted" to the MDF frame with machine screws it's off to get powder coat painted a nice white colour.
My work collauges keep joking around, saying that I am making a microwave! I have to admit it is rather similar. I'm not sure how well my sim can heat soup though. Perhaps i'll give it a try...  :laugh:
Rhydian
RojanTrojan
Some updated photos of my project. Aluminium case is almost complete. Just needs to get powder coating and then I have to move onto the wiring and testing....that'll be fun!
Rhydian
NAX228
Good work!
Nice compact cockpit you got there.
RojanTrojan
Almost complete. Just need to add a couple of decals and I'm done.
Rhydian
http://www.cessnaglasscockpit.blogspot.com/
Great work. That's going to be a sweet 172 simulator indeed. Will be a lot fun when completed.
For a "microwave oven " it is a very sexy one for sure....very very nice meticulous panel!!!
