How to interface annunciators ?
Started by Themax, September 04, 2010, 02:06:02 AM
Themax
Hello,
I have the Engravity desktop kit and I want to interface my led's to my mastercard from oc. I'll use 2 led's from 1 output for each annunciator. Will this cause a problem ?
What do you think is the best solution to connect the led's the easiest way ? I saw some guys doing it directly to the cards or via pcb's. What is the easiest solution to connect the led's to my oc cards ?
Can I use any type of led ? Is there something I should have a look when buying led's ? Do I have to use resistors ?
Thank you,
Maxime.
ekznamu
Hi Maxime,
you can put two LED's directly to an OC output (with a resistor !!).
The value of the resistor depends on the data of the LED's:
fall of voltage (Ud)
Current (I)
R1=(Usum - 2xUd)/I
Usum is the voltage of the OC-Output, it is 5V.
I hope this helps
Uwe
